Question about GE Profile PSI23NCR Side by Side Refrigerator
Water not coming out of refrigerator and ice maker not working
Water not coming out of the side by side and ice maker is not producing ice
  • 163 Answers
I would check water valve which is located behind ref.
Posted on Mar 07, 2009
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped making ice
hi,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water barely comes out and doesnt seem to be making ice
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
KitchenAid door ice and water dispensers don't work
Hi
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
GE model GSH25JFTACC ice maker not working
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Profile PSI23NCR Side by Side Refrigerator Logo
78 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
