Question about Black & Decker JE 1200 Juice Extractor
I used the juicer, cleaned it and the next day it no longer works. It will not turn on.
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
http://www.omegajuicers.com/juicers/masticating-juicers.html
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Jan 30, 2009 | Champion Juicers
Jack LaLanne power juicer 250 no longer works.
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Cleaning instructions
Try this. It works for the Stainless Steel juicer as well:
http://www.dooyoo.co.uk/juicer/jack-la-lannes-power-juicer/1055142/
Jul 31, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
Cleaning a Mesh Filter on my Juicer
The stiff brush that came with mine has worked well for me. Have you tried a fingernail brush or maybe some canned air?
Nov 19, 2007 | Juicers
Black & Decker JE 1200 Juice Extractor Logo
Top Black & Decker Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Black & Decker Juicer Expert? Answer questions, earn points and help others
