Question about Hotpoint Dryers
Rear drum bearing
Hi
been getting a thudding noise every revolution from my VTD00 unit. i took apoart the rear to have a look and found thruat bearing washer lying loose. does anyone have a GA drawing for this part of the machine.
many thanks
  • Hotpoint Master
  • 19,396 Answers
When it is like that you usually need to replace the drum bearing.
If the tub recently started making a lot of noise, and you can feel that the bearing had too much play when spinning by hand, that means that the drum bearing needed to be replaced.
You can find drawings and the schematics entering model number here.
Posted on Mar 07, 2009
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Drum won't spin on its own, makes a low buzzing
either your bearings have gone or u have something trapped between inner and outer drum
Mar 20, 2010 | Washing Machines
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Please rate my solution.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
Drum not spinning
sound like the rear bearing is stuck and the noise is the belt slipping on the idler pully and rear bearing needs replaced
Sep 15, 2009 | Hotpoint NWXR473EV Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Rear drum bearing
Ifthe tub recently started making a lot of noise, and you can feel thatthe bearing had too much play when spinning by hand, that means thatthe drum bearing needed to be replaced.
You can find the replacement part and the schematics here.
See also :
Mar 07, 2009 | Hotpoint NWXR473EV Dryer
Thud sound, once per rotation
that do fall under defective workmanship...but you have to look in your owner manual,,under your warranty page...i know if its stainless your covered..onthejob
Feb 03, 2009 | Maytag Neptune MDG9700A Gas Dryer
Dryers Logo
224 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
