Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Will not brew
I usually clean my barista once or twice a year. Take out the beans container and brush the steel grinder. It will rinse with good pressure but when I brew it comes out very slow to almost not at all.
Need help
Thanks
    New Friend:
  • 9 Answers
Do you also clean the brew group? there are two screens, one in the bottom of the basket and then the part that pushed down on top of it. the top screen is held in with a small screw. If you have tool that came with the machine, it makes it easier, but a philips screw driver would probably work just as good
Posted on Oct 30, 2009
Krups gx6000 grinder advertises removable burr grinders and there are no instructions, but is that the best way to clean them?
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
Jan 19, 2015 | Krups Gx600050 Conical Burr Grinder Black
Hi, The machine is trying to grind beans then states that there are no beans, yet the bean holder is full. We have dismantled the holder and cleaned out the grinder block, it worked once or twice then...
IT could be that the grind is too fine and the grinder is being clogged with coffee, first try adjusting to a coarser grind at least 2 to 3 numbers, if coffee flows into the brew unit you are good to go if not, then grind chamber needs to be vac out and cleaned then adjust grind and start over.
Apr 13, 2011 | Gaggia Titanium Espresso Machine
No coffeer comes out of the coffee spouts, maybe the steel filters are dirty, how can I cean them?
Before the instructions on how to clean the filters, Check the grinder to make sure is set properly.
It might be set too fine
Cleaning the brew unit filters
Wipe away any coffee residues from the steel filter in the funnel of the
brew unit with a sponge.
The chrome filter to the left of the funnel can be removed for thorough
cleaning. Check and clean the chrome filter regularly.
^ Remove the brew unit.
^ Fit the enclosed allen wrench (that you got with your machine) to the
connection point (see illustration in your manual) in the brew unit. Turn it
counterclockwise while supporting the chrome filter from below.
^ Remove the chrome filter with the screw.
^ Clean the filter with hot water and dry.
^ Return the chrome filter to the brew unit and secure it by turning the allen
wrench clockwise. Press slightly against the filter to allow threading.
Jan 18, 2011 | Miele Coffee System
"grinder blocked"
You can try th clean the grinder following the instructions here below
http://www.fixya.com/support/r5572092-saeco_italia_automatic_espresso_coffee
Good luck and thanks for your vode
May 08, 2010 | Starbucks Saeco Italia Digital Barista...
The coffee bean red light is on and it won't brew espresso. Cleaned out coffee bean compartment, turned off then back on and the light is still on and unable to brew. Have no idea where the manual is?...
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the backside of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jan 10, 2010 | Starbucks Saeco Italia Digital Barista...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
122 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
