Question about Lexmark X2350 All-In-One InkJet Printer
ERROR OCCURED DURING PREVIEW.
I am not able to scan my picture using lexmark x2350. in scanner and camera wizard i am getting the following prompt message:AN ERROR OCCURED DURING PREVIEW. IF THE SCANNER IS BEING USED, PLEASE WAIT FOR IT TO COMPLETE THE TASK, AND THEN CLICK PREVIEW.
  • Anonymous Mar 28, 2009
creativemind
  • 133 Answers
SOURCE: Lexmark 4200 printer/fax/scanner
hey buddy its nothing to do with your printer or monitor
but this problem occurs because of your operating system
first try this out
remove all printers from your start > settings > printers & fax
then reinstall your printer ( if you have usb printer remove cable while installing printer and plugin only when it asks )
then try to pring again
if its not printing then no solution buddy
you just have to re install your operating system
only this can help you
Posted on Mar 28, 2008
  • 2692 Answers
SOURCE: Can t scan
Reinstall it(the software and driver) with the updated stuff.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Posted on Jan 01, 2009
  • 684 Answers
SOURCE: scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 25, 2009
stabelabel
  • 51 Answers
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Posted on Mar 16, 2009
ihaveashed
SOURCE: How to Scan a Picture onto the Computer
These are the steps:
- Have it on the scanner setting (by pressing the big silver button on the left)
- Press page preview
- Press the colour or black print button (which are also known as the 'start' buttons)
- Then it should link it to your computer.
See ive done this but it STILL hasnt worked, these are the steps the manual says ... and my colour print and black print (aka start buttons) work!
Posted on May 11, 2009
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Nov 19, 2014 | Office Equipment & Supplies
Scan error 0x80210001
If you are only have this issue when using Scanner and Camera Wizard then this would be an issue with your operating system, and you will need to contact Microsoft. If you are able to scan using the HP software or MS Paint then the printer is working correctly.
Oct 11, 2013 | Samsung SCX-4300 Series
Can't remember how to scan document from Lexmark printer
There are several ways to scan. Place your document face down on the glass. If you have the Lexmark software loaded and running its monitor program, either press the scan button (the second button) on the printer or launch the Lexmark Imaging Studio (Start > All Programs > Lexmark 2300 Series > Lexmark Imaging Studio or double click on the shortcut on the desktop) and click one of the Scan options (pictures or text).
The All-in-one Center will open and you can adjust the scan settings and the destination for the scan. Click Scan Now to scan.
If you have Vista, you can also scan to Paint. In Windows 7, both Paint and Windows Fax and Scan will also acquire scans.
If you have problems, try a new USB cable or connecting to a different port. Scanners require bi-directional communication with the computer and can fail even when the printer works.
(We had a scanner that would preview but not scan due to a bad cable. So it can give an intermittent issue.)
May 17, 2010 | Lexmark X2350 All-In-One InkJet Printer
HOW TO SCAN PICTURES TO MY COMPUTER
Please put the picture into your scanner and find the program in your computer then scan or go to accessories , then click scanner and camera wizards to scan the picture.
Jan 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
Lexmark X5340 - All in One Printer/Scanner/Copier/Fax
Please follow the steps given below to add the scanner using Scanner and Camera wizard.
1. Plug your scanner into your computer.
2. If your scanner is "Plug and Play," the "Scanner and Camera Wizard" starts or double-click add device. Follow the instructions on your screen.
Note:
1. To open "Scanners and Cameras," click "Start," click "Control Panel," click "Printers and Other Hardware" and then click "Scanners and Cameras."
2. If you have a "Plug and Play" scanner, Windows detects it and installs it automatically.
3. If your scanner is not "Plug and Play," follow the installation instructions that came with the device.
4. If your scanner is not listed in the "Scanner and Camera Installation Wizard," try to install it using device manager.
5. After you install your scanner, you can test it.
Oct 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Canon MP470 will print and copy but not scan
The same thing happen to me. I have Windows XP. Try using the Scanners and Cameras Wizard.
Connect the MP470 to your computer, have it on and place the item to scan onto the scanner.
  • Go to the Start Menu
  • Click on Printers and Faxes
  • On the left of the screen there is an area titled, "Other Places"
  • Under the Other Places heading, click Scanners and Cameras
  • Select the WIA Canon MP470 device(double-click) This should open the Scanner and Camera Wizard.
  • Click Next and you will be taken to the Choosing Scanning Preferences screen. Here you can select picture type. If you click the Preview button your device will scan your item and display it in the preview box. Otherwise click Next.
  • Click Next to name the file, choose a file format and where to save it.
  • Click Next and your device should scan your item.
Sep 22, 2009 | Canon PIXMA MP470 All-in-One Printer
Lexmark series x2350 all in one scanner does not work.
You will need to uninstall and reinstall the printer driver again, since the driver installation seems to be incomplete. Please follow the steps given below:
To uninstall, please follow the steps given below:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark X2300 series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows" and unplug the USB cable.
You may copy and paste the web address below to access the Lexmark X2350 Vista driver to install:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:487:0:0&emeaframe=&fileID=12233&searchLang=en&searchLang=en&os_group=Windows%20Vista
Please use the following steps to download the Lexmark X2350 Vista driver to your desktop:
1. Select "Window Vista" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark X2350 scanner and printer drivers.
May 28, 2009 | Lexmark X2350 All-In-One InkJet Printer
Have an x2350 scan,copy and print i can print but
4. Click on "Next."
3. On the "File Download" screen, choose "Save." 4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
Apr 21, 2009 | Lexmark X2350 All-In-One InkJet Printer
All-in-one printer/scanner not working
did you installed software from the cd that came with it?
windows installe it as a scanner that you can use from Control Panel->scanner and cameras following the wizard...
to use the buttons on the scanner you must install software and configure it
Mar 15, 2009 | Lexmark All-in-One Printer, Scanner &...
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Lexmark X2350 All-In-One InkJet Printer Logo
227 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
