Question about Hotpoint NWXR473EV Dryer
Rear drum bearing
Hi
had a thudding sound every revolution from the dryer, suspected the rear bearing on the drum. took apart the rear end and a thrust washer fell off. does anyone have GA drawing for this part of the machine so i can see how it is meant to be assembled.
thanks
  • Hotpoint Master
  • 19,396 Answers
When it is like that you usually need to replace the drum bearing.
Ifthe tub recently started making a lot of noise, and you can feel thatthe bearing had too much play when spinning by hand, that means thatthe drum bearing needed to be replaced.
You can find the replacement part and the schematics here.
See also :
Posted on Mar 07, 2009
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Please rate my solution.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Heavy thumping noise with the turning of the drum
sounds like your rear bearing is bad, look in the rear center of your drum. for a crome pop out plug. Pop it out with a flat srew driver
there will be a nut that holds the drum in. take that nut off and you can lift the drum right out the front of your dryer. the front cover pops off after you take out the 2 screws from the lower front panel.
Aug 08, 2009 | Dryers
Makes a loud clunk once per drum revolution. There is a mark on the outside of the drum and I think it's hitting the motor housing. Could this be the drum bearing? Is it worth repairing? It is a IS60V
Hi, What brand is this and model #? It does sound like a bearing or rear roller has gone bad. Yes it will be worth fixing. I cam help you. Please let me know.
Thanks
Vic
May 13, 2009 | Dryers
The dryer heats fine but when the drum turns it makes a loud clinking sound like a bearing is going.
IT COULD ALSO BE YOUR BELT OR YOUR DRIVE BELT PULLY SOME DRYERS USE A GLIDER TO ROLL ON OR THAT THE DRUM SITS ON WHITCH IS JUST A PIECE OF LEATHER OR PLASTIC ECT. THAT THE DRUM SITS ON WHILE IT SPINS
Mar 08, 2009 | Dryers
Rear drum bearing
If the tub recently started making a lot of noise, and you can feel that the bearing had too much play when spinning by hand, that means that the drum bearing needed to be replaced.
You can find drawings and the schematics entering model number here.
Mar 07, 2009 | Hotpoint Dryers
Thud sound, once per rotation
that do fall under defective workmanship...but you have to look in your owner manual,,under your warranty page...i know if its stainless your covered..onthejob
Feb 03, 2009 | Maytag Neptune MDG9700A Gas Dryer
I have a Heavy Duty - 5 cycle dryer that is squeeking. We've taken it apart and found that it's not the belt but something towards the back end of the drum. Would there be a gasket of some kind that has...
Could be a dry rear drum bearing, if it has a removable rear panel, unscrew it and spray the end of the drum shaft and bearing with Wd40 or similar.
Please rate this solution
Dec 05, 2008 | Hotpoint TDC32 Electric Dryer
Rythmic thumping sound
probably the rear bearing or the drum shaft
Nov 15, 2008 | Asko T701 Electric Dryer
Dryers Logo
861 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
