I ahve a gigabyte 8ik1100 ver 2 motherbaord with 3 g memory ati radeon 9550 vgp am trying to install pinnacle pctv hd card and it cancels the vgp says its trying to share the memory, i have tried to change pci slots and assign irq to pci slots, have updated all drivers and bios and still same problem, can you help?
  • 15 more comments
  • charles harris
    charles harris Mar 07, 2009
    agp has its own mwemory if you did your research has its own power supply also
    tv card is try
    wow somew people dont seek before opening mouth please dont assume if your going to answer im tired of assumers thank youing to access the agp memory
  • charles harris
    uh no stop assuming please wow
  • charles harris
    wow some people dont know squat
  • charles harris
    please need help not assumptions
  • charles harris
    first u all should be reported for assuming things im just looking for solutions ur suppose 2 b the so called experts.
    all info is in the headline all makes all models do the research before u think u have the solution thanks
  • charles harris
    need serious inquiries only please, ametures stay away
  • charles harris
    alrewady have, the old one i was using and it works fine, something about this card tries sharing memory with agp memory how many times do i have to repeat this wow
  • charles harris
    the tv card is not a graphics card just tv tuner card
    and the radeon is only a graphics card not a tuner card
  • charles harris
    xp media center, already tried that idea did not work
  • charles harris
    charles harris Mar 08, 2009
    ok you dont understand this is a tv card not tv a tv card that you put into a pci slot so no there is not 2 dispalys in the properties why cant people read before they respond? wow this is a waste of time
  • charles harris
    people please read the info completly before you respond, im tired of people not reading the issue and just jumping the gun wow
  • charles harris
    finally someone who is getting to the issue thanks
    all irq are auto now i have already treid changing them they do not make a difference
  • charles harris
    i am running a gigabyte 8ik100 ver2 mother board
    1 agp slot 5 pci slots
    ddr 3 g memory
    p4 3.2 processor
    3 hard drives for storing important files
    450 w power supply
    ati radeon 9550 agp card 256 memory at dual channel 128 memory each channel
    run seperate power supply to agp
    trying to install pinnacle pctv hd card and every time it is in pci slot it shuts down the agp card tries to share that memory
    the agp is graphics only
    the tv card is a tuner card only anything else i missed you might need to know?
  • charles harris
    the memory i am running at ddr is kingston hyperthreading
  • charles harris
    tried that before doesnt work
  • charles harris
    for those who do not do the research, the 256 is its own memory if u looked up the agp i mentioned before you would see that
  • charles harris
    i personally dont like short cuts or those who take short cuts, its called diagnostics which means no short cuts, do your homework and everyone is happy that simple.
    I dont ask any more than what I would do, its called being thorough.
    To all of you who are really trying thank you for those who are just shooting in the dark and causing problems, you are the ones who give techs a bad name all around.
  • 916 Answers
If possible can you give me the configuration of your machine and irq settings, so that I can better assist you.
Posted on Mar 07, 2009
  • 479 Answers
right click on the desktop and go to the graphics properties .
there you will see the two display screens the select the ATI default and then check.
    Master:
  • 404 Answers
What operating system do you have?
this problem can be solved from the bios, reset it to defaults and restart. if that doesnt help try going back to bios and go to advanced settings of pci ports and play with setting there.
  • 679 Answers
It sounds as if you are trying to run an AGP and a PCI card at the same time. If this is the case you won't be able to do that. If the radeon is built into the board, you can only use a pci, or PCIE. The only way you can use the pinnicle is in a different motherboard or to disable the video on the motherboard, and try the PCI slot again, it may or may not work
  • George Bill
    George Bill Mar 07, 2009
    Ok calm down, the computer is treating them both as "video cards", it doesn't know the difference. Someone should have mentioned that to you. Just try this "indulge me", go into the device manager, and disable the onboard graphics. Then restart using the tunercard as the only card. see if it works then.
    Sergeant:
  • 320 Answers
Check out with another video card and try.
  • 154 Answers
Try a external adapter.
  • 19,396 Answers
Sometimes you cannot use two cards that need shared memory at the same time, you may need to replace the video card.
  • 3 more comments
  • Ginko
    Ginko Mar 07, 2009
    It is not a matter of motherboard, it is the cards.
    When a card uses shared memory, it means that this is reserving the first block of your ordinary computer RAM for its use.
    Two cards with shared memory will cause troubles to each other , and often do not work at same time.
    Buy a different video card with built in memory and disable the built in video card.
    You need a video card like this one:Evga e-GeForce 6200 256 MB DDR AGP Graphics Card ...
    With his own memory chips.
  • Ginko
    Ginko Mar 07, 2009
    If you are using an AGP card , what is your AGP card please, from first description there was no mention to your AGP card.
    assigning irq (interrupt request) to pci slots wont have any influence to use of shared memory.
    Thanks for your collaboration.
  • Ginko
    Ginko Mar 07, 2009
    Istead of commenting about assumers , give us the model of your AGP card, and also of your Pinnacle card.
    Otherwise I will soon start assuming that you are here to make an inproper use of yours and ours time.
    Many Thanks.
  • Ginko
    Ginko Mar 07, 2009
    Well guys, this looks like a joke, hope the refund is going to be locked, I reorted the abuse.
  • Ginko
    Ginko Mar 07, 2009
    And to the user, there may have been some misunderstanding here, but I willbe grateful if you can give us details on the graphic adapter used and on your pinnacle card .
    Please retain from commenting about squatters or assuming, that does not make any sense to us, and for us it is a waste of time.
    I will answer within 24 hours.
    Many thanks.
    Regards.
  • 13,433 Answers
You may need to get another motherboard for this to work.
  • 3 more comments
  • Ekse Mar 07, 2009
    Where do you get this message?
  • Ekse Mar 07, 2009
    AGP card does not share memory there is only one card not many cards ?????
    Where do you get this error message do you get it when you open the tv on your computer or? Please clarify a little.
  • Ekse Mar 07, 2009
    Also please include the model of your pinnacle pc tv card
  • Ekse Mar 07, 2009
    I think he is only looking at Cysiszones solution now. Well he is reported and I hope he will be gone soon.
  • Ekse Mar 07, 2009
    Please clarify the error message or problem that happens, please post in detail what happens when you attempt to install the device or to turn it on to watch tv with the software.
    That is not clear.
    Thank you.
I install Burnout paradise the ultimate box and got an error when try to play the game... this machine gpu does not support shader model3 which is required to run this game. I have Intel(R) G33/G31 Express...
you must upgrade your graphic card. the problem as nothing to do with your chipset. This are the minimum requeriments to run the game:
OS: Windows XP/Vista
Processor: Intel Pentium 4 @ 2.8 GHz / AMD Athlon 64 3000+
Memory: 1 Gb
Hard Drive: 4 Gb free
Video Memory: 128 Mb
Video Card: nVidia GeForce 6600 / ATI Radeon X1300
Sound Card: DirectX Compatible
Network: Broadband Internet Connection for Online Multiplayer
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Recommended System Requirements
Processor: Intel Core 2 DUO @ 2.5 GHz / AMD Athlon 64 X2 5200+
Memory: 2 Gb
Video Memory: 512 Mb
Video Card: nVidia GeForce 8800 / ATI Radeon HD 2900
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Aug 26, 2012 | Computers & Internet
Tip
A list of the compatible PCI-Express 16X Graphics cards for a PCI-Express...
Having trouble finding out which graphics card will work with your PCI-Express motherboard? Here is a list all PCI-Express graphics cards for AMD/ATI Radeon. This list is in descending order. (The top graphics cards from each manufacturer are more recent, have greater memory and are faster while the bottom are older, have less momory and are slower).
If your Motherboard supports PCI-Express X16 then here is a list of compatible ATI/AMD Radeon Cards.
AMD Radeon 6000 Series - (AMD Radeon HD 6870 and AMD Radeon HD 6850)
ATI Radeon 5000 Series - (ATI Radeon HD 5970, ATI Radeon HD 5870 Eyfinity 6, ATI Radeon HD 5870, ATI Radeon HD 5850, ATI Radeon HD 5830, ATI Radeon HD 5770, ATI Radeon HD 5750, ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5870, ATI Radeon HD 5550 and ATI Radeon HD 5450)
ATI Radeon 4000 Series - (ATI Radeon HD 4870 X2, ATI Radeon HD 4890, ATI Radeon HD 4870, ATI Radeon HD 4850, ATI Radeon HD 4830, ATI Radeon HD 4770, ATI Radeon HD 4600, ATI Radeon HD 4550, ATI Radeon HD 4300 and ATI Radeon HD 4200)
ATI Radeon 3000 Series - (ATI Radeon HD 3800, ATI Radeon HD 3600, ATI Radeon HD 3400)
ATI Radeon 2000 Series - (ATI Radeon HD 2900, ATI Radeon HD 2600, ATI Radeon HD 2400)
ATI Radeon X Series - (ATI Radeon X1950, ATI Radeon X1900 and ATI Radeon X1800)
If your Motherboard supports PCI-Express X16 then here is a list of compatible Nvidia Cards.
GeForce 500 Series - (GeForce GTX 580)
GeForce 400 Series - (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420)
GeForce 200 Series - (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 220, GeForce GT 210)
GeForce 9 Series - (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO, GeForce 9400 GT)
GeForce 8 Series - (GeForce 8800, UltraGeForce 8800 GTX, GeForce 8800 GTS (640 MB, 512MB and 320 MB versions), GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8500 GT, GeForce 8400 GS)
GeForce 7 Series - (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600)
GeForce 6 Series - (GeForce 6800 Ultra, GeForce 6800 GT, GeForce 6800 GS, GeForce 6800, GeForce 6800 XT)
For a list of compatible AGP8X Cards for an AGP8X Motherboard click on this link to take you to my other tips page. http://www.fixya.com/support/r6784133-list_compatible_graphics_cards_agp8x
on Feb 10, 2011 | Computers & Internet
Tip
A list of compatible Graphics cards for an AGP8X Motherboard.
Due to text length contraits I've had to seperate AGP8X Graphics Cards from PCI Express Graphics Cards
Having trouble finding out exactly which Graphics card will work in your AGP8X motherboard? The following list displays all the compatible Graphics cards for an AGP8X motherboard in decending order (Top Graphics cards are faster than bottom ones in each catagory)
If your Motherboard supports AGP 8X then here is a list of compatible Nvidia cards.
GeForce 6 Series - (GeForce 6200, GeForce 6600GT, GeForce 6600 and GeForce 6600 LE)
GeForce FX Series - (GeForce FX 5950 Ultra, GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900 XT, GeForce, GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE, GeForce FX 5200 Ultra, GeForce FX 5200 and GeForce FX 5500)
GeForce 4 Series - (GeForce 4 Ti and GeForce 4 MX)GeForce 3 Series - (GeForce 3, GeForce 3 Ti 500 and GeForce 3 Ti 200)
GeForce 2 Series - (GeForce 2 Ultra, GeForce 2 Ti, GeForce 2 Pro, GeForce 2 GTS and GeForce 2 MX series)
GeForce 256 Series - (All)
If your Motherboard supports AGP 8X then here is a list of compatible ATI/AMD cards.
ATI Radeon X Series - (ATI Radeon X1050, ATI Radeon X1300, ATI Radeon X1550, ATI Radeon X1600 and ATI Radeon X1650)
ATI Radeon 9xxx Series - (ATI Radeon 9550)
For a list of compatible Nvidia PCI-Express cards for a PCI-Express Motherboard currently on the market click on the following link to take you to my other tips page. http://www.fixya.com/support/r6784358-list_compatible_nvidia_pci_express_16x
on Nov 10, 2010 | Computers & Internet
Need a good video card upgrade for my HP a6658f... one that will fit in the space provided and not require too much power (300 watt power source). The original is starting to go, and I would like to...
Your system has, from factory a Benicia #IPIBL-LB motherboard and has a PCIe x16 slot. You could go with any card PCIe x16 that is within your power range. I personally like the Gigabyte, Asus, Radeon HD cards because you can get sound and audio out of the card, unlike the Nvidia cards. The card you would more than likely be looking for would be a midrange card going anywhere from 40.00 to 90.00. There are many to chosse from but, I would get one that is Windows 7 or at least Windows Vista ready. This AMD's site and this card would work for you. It requires
300w supply and would do a good job.
http://www.amd.com/us/products/desktop/graphics/ati-radeon-hd-4000/hd-4550/Pages/ati-radeon-hd-4550-overview.aspx
May 24, 2011 | HP Pavilion a6658f Desktop PC
What video cards are compatable
This computer comes with a Nvidia FX5200 so this tells me that it can support any AGP8X Graphics Card.
Here is a list of compatible GeForce cards for this PC's.
Here is a list of compatible ATI/AMD cards for this PC's.
You should already have a GeForce FX5200 so better than that is the 6600 and 6600GT.
Feb 22, 2011 | Gateway 500XL PC Desktop
I dont have vga driver i have ATI Radeon 9550 128MB DDR operating system Windows Xp please can u help me ??
Click here and download the XP drivers for ATI Radeon 9550 from ATI/AMD Official Support.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Vectra VL420 PC Desktop
Gigabyte GA-EP41-UD3L Intel G41 (Socket 775) the motherboard doesn´t run with an ati hd radeon 4650 gddr2 1gb constantly rebooting already tested with another ati hd radeon but gddr3 and runs can...
The card needs to be connected to a power source within the case, the main power supply, otherwise it will shut the computer down when it overheats. Make sure the fan on the card is moving.
Apr 12, 2010 | Intel Computers & Internet
When I insert my graphic card Ati HD 4850,my system does not boot.I am getting post code error 52 -Test memory(clear all extended memory to 0).Also the fan spins to 100% and does not want to stop.Two...
are your system meet the requirement???
ATI Radeon™ HD 4850 System Requirements
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Minimum 1GB of system memory
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray™ playback requires Blu-ray drive
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
Dec 12, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
