Question about Freezers
BEKO frost free combi fridge freezer model number- CDA 563 F
Hiya,Can you help??We have a BEKO frost free combi fridge freezer which has stopped working, but the light still works when the door is opened. There is also a bubbling sound coming from it when switched on.
  • Anonymous Apr 04, 2009
    light works fridge and freezer stopped for 24 hrs. then started back up? engineers havent got a clue still under gaurante. i should have it replaced if beko will let me?
  • getz83 Apr 14, 2009
    mines defrosted itself and has stopped working,it also makes a bubbling sound.but it only a year old.gona turn it of and leave it 24 hrs
4 Suggested Answers
  • 68 Answers
SOURCE: My beko frost free fridge freezer is not switching
you would have to find out what temperature your freezer is. if it is reaching -20 then it should be cutting out and chances are the thermostat is stuffed
Posted on May 01, 2009
  • 4793 Answers
SOURCE: beko frost free fridge freezer keeps icing up
if the freezer is in a cold place (below operating temp of freezer)the fan housing is the first to freeze.solution is move it to a warmer room.a common fault with freezers in garages.....
Posted on Feb 05, 2010
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
How can I Stop the bleeping on my CDA FW 381 freezer. It alarms for approx 30 seconds,but I dont think the temperature is rising. Can I isolate the alarm.
You need to use a thermometer to be sure but realize the alarm indicated a certain temperature point has reached or exceeded, not that the temperature is rising.
Try these links for additional help.
Redirect Notice
Beko CDA 565 FS Manual
Mar 02, 2015 | CDA Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
My beko frost free fridge freezer is not switching on and off. it is running constantly and the fridge is now very cold on number 1 setting?
Apr 30, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
611 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
