Question about Nintendo Wii Console
Wii controller We can use + and - buttons but thats it, they do not get the little hands on the screen to pick a game. any help would be great
  • 38 Answers
It sounds like your sensor bar is faulty(the lone black bar) Make sure it is plugged in and at the appropriate place.Just move it in front of the tv and try again, adjust it if no help buy new one. It would also be good if you had another controller just to rule out the controller being faulty.
Posted on Mar 14, 2009
How can i connect my wii thru my wireless?
  • instructions on how to connect wii thru your wireless
    Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2
    Press the "A" button on your Wii controller to continue from the warning screen.
  • 3
    Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4
    Click the "Wii Settings" box on the right.
  • 5
    Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6
    Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7
    Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Dec 06, 2011 | Nintendo Wii Console
    On my wii remote at the bottom of the remote belong 1&2 them lights all flashing and it will not pick up we change the batties still not working can you help me..
    1. Press the Power button on the Wii console to turn it on.
    2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
    3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
    This procedure must be followed for each additional Wii Remote added to your system.
    Nov 29, 2010 | Nintendo Wii Console
    Why does my wii controllers not work any more lights are on but it does not pick up the hand on the screen
    hello,
    i have looked around for you and id suggest you try to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it.
    and it should work like a charm to get you back to throwin some curve's in wii sports!!!!!
    i hope i have helped and i hope it works!! let me know how it works
    Jan 03, 2010 | Nintendo Wii Remote Controller
    Both my wii controls work when you press the buttons and the lights are on but there is no cursor(hand) on screen.
    Make sure the sensor bar that you put on top or below the TV is where it can pick up signals, and it works best if it is above the TV.
    Nov 08, 2009 | Nintendo Wii Console
    Wii remotes blinks several times but doesn't work.
    you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
    Jul 21, 2009 | Nintendo Wii Console
    My Wii remote blinks blue lights but it won't work with the Wii
    you have to press A and then the remote buttons at the bottom will turn blue and make sure you have the gray thing that sits on top of ur tv is where you can directly aim the remote at and the little hands should appear.:) Hope it helps.:)
    Jun 20, 2009 | Nintendo Wii Remote Controller
    Wii remote not working right
    Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
    Mar 06, 2009 | Nintendo Wii Console
    Wii mario kart, second wheel won't turn
    I tried resyncing from the main screen, but one of the wiimotes still didn't work. I read to smack the wiimote facedown in your hand a couple of times, and that worked!!!
    Apparently the motion sensor can get stuck inside, although it doesn't totally make sense, because previously when the wiimote didn't steer, it still moved on the screen to choose character, car, etc.
    Dec 25, 2008 | Nintendo Mario Kart (Wii) for Wii
    Wii system stuck on the first screen and the hand is not come up
    Are the Wii Remotes Batteries dead? This can be a common problem as well as Wii Remotes becoming unsynced to the Wii. To resync the Wii remote:
    1. Open The Small Door on the front of the Wii and Take the Battery Cover off of the Wii Remote.
    2. Press the small red "Sync" button on the Wii and then Press the Small Red Button on the Wii Remote.
    You should he a "beep" through your TV speakers that confirm your Wii Remote have been reconnected.
    I hope this Helps. Take Care. =)
    Dec 08, 2008 | Nintendo Wii Console
    Wii Controller
    ok well there is a little compartment on the face of the wii that you have to open and it should reveal a red button which will set the wii to pick up any signals from a wiimote but to get the signal from the wiimote you need to open the compartment where the batteries go and there should be another red button you have to press and hold both the buttons at the same time and they should pick up each others signals.
    Jul 30, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    26 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
