Question about Nikada LD1321 32 in. HDTV-Ready LCD Television
Can't see my laptop screen on LCD tv even if I connect VGA cable!
  • Anonymous Mar 30, 2009
    while my laptop is booty up my tv recieves its signal but then it goes away when my laptop sreen turn black while booty
Try to hold the FN + F7 key at the same time.
Posted on Apr 26, 2009
5 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Posted on Apr 20, 2008
skotkolr
  • 558 Answers
SOURCE: HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
the tv must be set to vga input
Posted on May 10, 2008
electronick
  • 505 Answers
SOURCE: no picture when vga cable is connected
Most tvs can only handle a couple resolutions (ie 640x480) through the pc input. Even some HD tvs can only do 480. Check that your video is turned on and setup to the acceptable resolutions.
right click your desktop
go to properties
click settings tab
click on the 2nd monitor
make sure the box is clicked at the bottom
"extend my windows desktop onto this monitor"
instructions for windows xp
Posted on Dec 16, 2008
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
Oct 22, 2012 | Toshiba Sattelite A105-S2051 Notebook
Why wot it let my packard bell easynote r4250 connect to a tv through a VGA ports
There is not enough info here. Many things could be wrong. Are you actually plugging the VGA cable into the VGA port on the tv or computer? Does your tv even have a VGA input? Is your tbs input switched to the tv? Please contact me with questions.
Feb 28, 2011 | Packard Bell EASYNOTE R4250 COMPATIBLE...
How to connect an acer 3680 with windows xp to lcd tv
hi khan, its very easy to do this process , you can connect vga card just see this video
immortal4u_0.jpgGood luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Acer Aspire 3680 Laptop
How can I connect my pc to tv
The DV6000 has all the drivers needed to connect to a TV as long as the TV has either a s-video connection or a pc vga input. The vga input is usually blue in color on the tv but on the laptop it may appear dark tan or brown and does not have screws to hold it into place, the plug just fits in and tension holds it in place. Once you connect the cables, change the input on the TV to the type of cable you are using. The laptop should automatically pick up the signal from the device and load the driver for it. The desktop should appear on the tv if the output signal and input are matched. The icons may appear different on the TV if the resolution is not close to a match but that should not be a concern unless it is cutting some of the picture off, in that case all you have to do is change the resolution to one that is easier for the tv to show. The dv6000 allows you to toggle through the video output settings by holding down the Fn key and tapping the F4 key, this will change the display to both laptop lcd and tv, just tv, just laptop lcd etc. It will even let you extend the desktop from the laptop to the tv or from the tv to the laptop, making one long display side to side.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Philips 42" HDMI connection to VGA on laptop connection problems
Feb 10, 2009 | Philips 52 In. LCD HDTV
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Jan 07, 2009 | Acer Aspire 5100 Notebook
Jerry G.
Apr 20, 2008 | Televison & Video
Nikada LD1321 32 in. HDTV-Ready LCD Television Logo
1,105 people viewed this question
Top Nikada Televison & Video Experts
Electro Med Services...
Are you a Nikada Televison and Video Expert? Answer questions, earn points and help others
