2wire Router
Problem for 2wire (1000-400108-001) Router
Modem router advise
By godwind on Mar 07, 2009
I have an AT&T 2wire modem router DSL . . two problems first connecting to the internet via explorer (os = XP) usually first attempts end in not responding . . the second problem is range . . if I disconnect my laptop from the hard wire connection and go out say to the garage I can not connect . .distance is about 50 to 75 ft note common wall has metal sheeting due to fire code . . question do I have to use a modem provied by AT&T to use their service? how can I increase the range ? What router modem setup would you recommend to include USB for cammon share external hard drive? Are there any fixes for the internet connect problem?
Clarification Request
Posted by meroderick on Apr 06, 2009
How do check the setting in the router?
Same Problem
Apr 06, 2009
-   I reset my wireless router, now it won't even let me log onto the computer or put any of the router information into my computer? What do I do now?? -   meroderick
Solution #1
posted on Apr 02, 2009
Somewhat Helpful)
charlie_r
Rank: Guru
Rating: 90%, 40 votes
Have you checked your wireless settings in the router?
The default power setting is 4, you can try setting it to the highest, 10.
Also set the channel to 4,5,6,7, or 8. those have the highest output.
Comments:
Apr 17, 2009
- open your favorite browser, and type into the address bar http://gateway.2wire.net
at the top of your screen, click on home network
on the right side of the home network screen in the lower box is wireless network edit settings. click the button
you will be asked to input your password
at the bottom of the next screen there is <wireless mode> this should be default 802.11g. if it isn't set it to that
next you will see <DTIM> should be default 1
next is <maximum connection rate> set it to the highest setting (default for 802.11g is 54 Mbps)
the last is <power setting> default is 4, set to 10
Was this helpful?
Yes
No
Popular Solutions for 2wire Router
Questions and Unsolved Problems for 2wire Router
Do you recommend 2wire (1000-400108-001) Router?
Answer
Answer
Can I hook up a router with ethernet and wireless to my Westell Model E90-610030-06 DSL2+ Router to... (More)
Answer
I have a dovetail jig but dont know how to use it
Answer
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to... (More)
Answer
how to get chatspace workin on a netgear 2wire router
Answer
no power to router even after unplugging and resetting.....light is red
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repairmen
in , AR
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
