Question about One For All URC-4021 Remote Control
Key markings worn off
Key markings have worn off my remote and I need to know where the set button is in order to put a code into for a new TV
What markings do u need do u hae the instruction booklet with the codes
Posted on Mar 22, 2009
What are the 3 digit codes for Huayu HR-N99? For samsung. I lost my copy. Please help!!
Input code set method
1, turn on the TV power supply, will be the normal play of the TV set, find out from the code table to the corresponding code by the remote control of TV brand.
2, hold the "set" button on the remote control, until the work light is lit up, let go of "set" key.
3, I just find a set of three digits code. Light is put out.
4, check the validity of other buttons, the effective set, invalid, repeat steps 1-3.
Search code sets method
1, let the normal play of the TV set, will be on the TV remote control.
2, hold the "set" button on the remote control, until after the work light is lit up.
3, of the press "volume +" key.
4, when the volume of symbol to appear on the TV, press the "set" button, the light is put out.
5, check the other remote control button is valid. If the button is valid, set up successfully, if invalid need to repeat step 2-4, until find the code that suits your TV set.
http://www.huayu.cc/EN/_XinWenZhongXin_v283.aspx
Feb 22, 2017 | Televison & Video
QuantumFx Rem-200 remote codes for philip TV no set up button
Hold down the tv button and then press and hold down the power key untill the light comes back on then press and release the power key untill tv comes on or goes off then press the (dvd) stop key and it is programed
Aug 25, 2012 | Universal Remote Control URC-200 LCD...
IR Remote control 103781
OK first and foremost not all tvs are supported by Dish remotes. This is especially true of combo units bbut here is the easiest way to program the remote if the tv is supported:
Press and hold the clear tv button on the top of the remote until all buttons across the top light up.
Now press the smallred tv button and release it.
The top tv button should be lit constantly now.
Now press the arrow up key slowly until the set turns off.
Once it has press the arrow down button once and then the arrow up button to see if tv turns on.
If it does press the pound key and release.
The topmost tv buttton will flash three times.
You are now ready to press the SAT key on the top of the remote and watch tv as usual controllling volume etc with the remote.
If the set turns off but you can not get it to turn back on turn the set on manually and start the process again- it will not go back through the codes you already had tried.
If you notice the tv button flashing rapidly it means you are at the last code and need to go back the other direction or that there is no code for your set.
If the set turns off but will not turn back on then you have a partial code which will not perform properly. Thanks for using Fix Ya.
Mar 12, 2009 | DISH Network IR Remote Control
I need new codes for a direct tv reciever d10,thanks
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
Jan 28, 2008 | One For All URC-4021 Remote Control
What to press to put code in
http://www.ofausa.com/remote.php?type=URC4220
To input a code hold down the setup or "magic" button until the led flashes twice, when this happens you are ready to type in your code.
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 09, 2008 | One For All URC4220 Remote Control
Battery died and need to set up codes for Fisher TV
http://www.ofausa.com/remote.php?type=URC3021
Many thanks
Mark
Jan 06, 2008 | One For All URC-3021 Remote Control
Missing codes
http://www.ofausa.com/remote.php?type=URC6131
Many thanks
Mark
(www.sparky-uk.com)
Dec 14, 2007 | One For All URC-6131 Remote Control
Need code to link my bush tv with a kameleon remote control
Hello, you can try the search method,
Many thanks
Mark
(www.sparky-uk.com)
Oct 30, 2007 | Radio Shack Kameleon 8-in-1 Universal...
Oneforall remote
Hello, do you know if you have the right code for your remote programmed into it?
if not try the search method,
Many thanks
Mark
(www.sparky-uk.com)
Oct 21, 2007 | Logitech Harmony 880 LCD Remote Control
I can't find a code.
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
Feb 24, 2006 | RCA RCR450 Remote Control
One For All URC-4021 Remote Control Logo
56 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
