Question about Kenmore 73952 Gas Dryer
Dryer not drying correctly
Will not dry. I cleared all lint. heating element gets cherry red for a while and then cools. Should this be happening. The inside of the dryer is warm but not hot. went outside to check to see if the tube was stopped up and its not. Air is hot. What do I need to check next.Kenmore 70 series dryer
  • Kenmore Master
  • 8,220 Answers
The coils are getting hot and won't open the gas valve. replace them dudes
dryer not drying correctly - 291385a.jpgMore HERE
Posted on Mar 07, 2009
Dryer shuts off before dry. not dry.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 06, 2011 | Kenmore Elite HE4 Electric Dryer
SENSEON DRYER WILL RUN GOOOD FOR 1 OR 2 CYCLES IF STILL WET AND PUT THEM BACK WILL NOT HEAT UP AND DRY THEM WILL GO FROM SENSING TO COOL DOWN THEN WONT DRY ANYTHING
HI,
t normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequentlythere's an obstruction in the vent duct from the dryer to the outsideof the house. For the dryer to heat properly, the duct must be cleanand clear of lint or any other substance.
Heating element Yourdryer's heating element may be partially burned out. If it is, yourdryer still heats, but at such a low temperature that it takes three orfour times as long to dry the clothes. If the element is partiallyburned out, replace it.
Internal ductwork Yourdryer has some internal ductwork. If it gets clogged, your dryer can'tdry properly. In most dryers, to get to the internal ductwork to clearthe clog, you have to substantially disassemble the dryer. A quick wayto check for internal clogs is to remove the lint filter and use aflashlight to inspect the inside of the duct. If it looks clogged andyou can't clear it using your vacuum, contact a qualified appliancerepair technician.
Cycling thermostat Althoughthis isn't a common problem, one of the thermostats that controls thetemperature in your dryer may break and cause the dryer to heat poorly.If so, you need to replace it. The thermostat is usually a small,round, black device mounted to an oblong steel plate. The plate ismounted to the internal ductwork with two screws.
Jul 29, 2008 | Dryers
Dryer problem
have ou check the heating element, the thermal fuse..?
Jul 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Amana Special Edition Electric Dryer Model ALE868QAW not drying
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
Laundry not getting dry
Vent
Heating element
Internal ductwork
Cycling thermostat
Jul 18, 2009 | Dryers
Too long to dry my clothes
HI,
Vent
Heating element
Internal ductwork
Cycling thermostat
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
Vent
Heating element
Internal ductwork
Cycling thermostat
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
My dryer heats up, but the clothes dont get dry w/o 3 full cycles
Remove the exhaust vent from the rear of the dryer. Run a timed load at 45 minutes. If it dries correctly clean your connecting vent your wall vent and the lint from inside the machine.
May 27, 2009 | Dryers
Heating element stays on
Vent
Heating element
Internal ductwork
Cycling thermostat
Mar 07, 2009 | Whirlpool LER7646J Dryer
Kenmore 73952 Gas Dryer Logo
183 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
