Question about Uniden TRU8885 Digital Answering Machine
Nseed to reset message on answering machine
Need to reset message on answering machine
  • 57 Answers
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Posted on Mar 09, 2009
Answer machine says memory full how do I reset it
Delete old messages. It doesn't need resetting, just the old messages removed. Likely one at a time.
Dec 31, 2015 | Lands Phones
How do I reset recording with my own message
The KX-TGA641 is the handset. You need to refer to the documentation for whatever answering machine you have connected to your phone line. Failing that, repost your question identifying the answering machine.
Feb 18, 2013 | Panasonic KX TGA641 Cordless Phone
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
I have a VTech Dect 6.0 cordless phone answering machine. I disconnected the power to the answering machine in error. I want to reset the time on the answering machine. How do I do this? My email...
Hi there,From answering your telephonemag-glass_10x10.gif when you are busy or away, to broadcasting a generic message to callers, an answering machine is a key part of your home or office phone system. When the device is working properly, it not only records and playbacks messages, but also informs you of the date and time of the call. If your answering machine is not recording messages, displaying an error code or is presenting another problem, you can reset the device and restore it to a working state.
Aug 03, 2010 | Vtech Digital Cordless Telephone VT-2568
Can this machine be turned off and on remotely
There are zero message on the machine, but the machine says "messages full" to the caller after if answers and plays my recorded message. It also flashes "F" on the display. I can't figure out how to reset it so that it will answer my calls. Can you help?
Mar 20, 2008 | GE 29871GE3 Digital Answering Machine
Power failure message.
Power Failure Recovery
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Mar 11, 2008 | AT&T 1726 Digital Answering Machine
Answering machine
Hw do I reset/reprogram Model: 29871GE3 answering machine? No manual.
Nov 20, 2007 | GE 29871GE3 Digital Answering Machine
Answering machine not working
TRY INSTALLING NEW TAPE. IF IT IS DIGITAL THAN YOU NEED TO RESET MESSAGE.
Oct 12, 2007 | Lands Phones
Need a instruction manual
Click the following link...
http://support.radioshack.com/support_phones/doc69/69751.pdf
There's your answer!
Don't forget to click "FixYa" below!
Thanks
Len
Oct 07, 2007 | Radio Shack 3822 Digital Answering Machine
Uniden TRU8885 Digital Answering Machine Logo
1,456 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
