Question about Dell Dimension 4700 PC Desktop
Factory reset dell dimension 4700 series
How can i wipe everything off my computer.plz help!!!
  • Anonymous May 10, 2009
    is there a keys to press to restart my dell computer to factor setting?
  • 21 Answers
HI Dear if you want to clean your system i think u want to reinstall the windows before that u want to clean your drives if u want to clean C: drive then u have to restart the computer with Win Xp or Win Vista Boot able Cd then after loading option you will see of format when u click it it will clean your that selected drive if u want to clean other drive the go to my computer right click on drive and click format ok .
Posted on Mar 07, 2009
  • 62 Answers
The computer came with a bootable reinstall CD use that.
Need to reset factory settings (which wipes everything out) on a Dell Dimension 1100 PC Desktop. I DO NOT need to restore to an earlier date. I do have a Windows CD to re-install--don't need ideas on how...
Follow the prompts on the os re-install disk and select to reformat the partition in use.
This will wipe everything. you will need to re-install all your drivers too.
Sep 27, 2013 | Dell Dimension 1100 PC Desktop
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
My pc boots up but icons or start button and an error states that an application could initialize properly.
You should try to reinstall Windows, try and get all of your stuff off of your computer because it will wipe everything. If you can't/don't want to do this yourself you should take it to a computer repair store and they will be happy to fix it for you.
Jul 28, 2011 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dimension 4700 how do I fully restore computer to original setup
To restore your dell pc you put in the restore disk that came with the pc and reboot the pc. It will tell you to press any key to boot from the cd. After pushing any key it will begin to boot from the cd and reinstall windows just as it was from the factory. Depending on the operating system the restore cd will look something like this.
Apr 29, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700
Try resetting the BIOS, see if the drive re-detects
  1. Boot to BIOS F2
  2. turn on all 3 lock lights (NUMLOCK, CAPSLOCK< SCROLL LOCK)
  3. Press ALT+E, then ALT+F then ALT +B and system will reboot and re-detect drives
  4. If HDD is not detected, reseat data and power cable connections, try again
  5. if still no go, then HDD has likely failed
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
Which Dell System does Reinstallation CD P/N 1R594 go with?
DELL Dimension series (mostly dimension 4700) and it is windows xp pro reinstallationn cd.
thanku!!1
Jan 31, 2010 | Microsoft Windows XP Professional
Beep problem Dell Dimension 4700
Beep problem update - Dell 4700. Last night started computer - cold boot. The screen had just started to light up and then went black and computer started beeping in an interrupted sequence. Fan speed increased considerably (suggesting overheat?) Shut it down and attempted two restarts with no success. This morning I unplugged all cords, opened case, pulled and reset memory cards and vacuumed inside. The computer was very clean so really don't suspect that dust was an issue. Buttoned it back up plugged in plugs and restart successfully accomplished. Have no clue why. Some square electrons, I guess.
Dec 19, 2007 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
894 people viewed this question
Alun Cox
