Question about Garden
I need to set the low ,high and the throttle. what are the setting. HARD TO START AND STALLS WHEN CUTTING
  • pataluna Mar 12, 2009
    thanks a lot it works
steve_lima
  • 181 Answers
SOURCE: Set fuel mixture with high and low
starting settings are 1 turn on high side and 1 turn on low side.most likly you will be at 1 1/2 on low side and 1 1/4 on high side
Posted on Jan 09, 2009
SOURCE: poulan 2450 wont start
After warming up the engine at part throttle for a couple of minutes, clear it out with a 3 second burst. Then idle the engine.. If the chain rotates, turn the idle speed screw to the left (CCW) until the chain stops.
Turn the LO NEEDLE slowly to the right (CW) to find the fastest engine speed. If this causes the chain to rotate, repeat idle screw adjustment to stop the chain from rotating.
High speed (with throttle wide open). Set needle 1-1/4 turns open, checking for smooth acceleration by opening the throttle wide for 3 seconds. If the saw stumbles, turn needle to the right (CW) 1/8 turn @ a time until smooth acceleration is obtained. Try a saw cut to see if adequate power is available. Continue making 1/8 turn adjustments (CW) until saw shows a power drop when asked to cut. (This indicates too lean a mixture setting.) Then, from the setting in step 3, turn the HIGH NEEDLE 1/4 turn to the left (CCW). Check the cutting ability of the saw again. This should be the best setting for your particular altitude, temp. and humidity conditions.
To pre-set before initally starting the saw, turn LOW and HIGH and IDLE screws in gently till each one just stops. Then turn each out (CCW) 1 - 1 - 1 1/4 turn.
Hope this is helpful. Try www.zamacarb.com/tips.html Select the "Tech. Guide"
Good luck and God Bless.
oft
Posted on Jan 22, 2009
  • 23 Answers
SOURCE: 4 y/o oulan chain saw hard to start and quit running, no spark.
TRY RUNNING AT HALF OR FULL WHEN IT DOES POSSLBY BAD GAS/MIX IF YOU CHANGED THAT ALREADY CARB PROBALY NEED TO BE CLEAN
Posted on May 17, 2009
dontbother10
  • 2220 Answers
SOURCE: What is the factory setting for the throttle and
Workshop Manual for a Husky 357XP/359 (2006 - I will wager yours is similar) follows:
The Husky workshop manual on Appendix A (USA, this probably does not apply to your vintage saw) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles. There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move".
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix. I could not find an OM for a 1994, a 1995 says mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH.
Lou
Posted on Feb 24, 2010
dontbother10
  • 2220 Answers
SOURCE: high & low carb needle settings
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 16, 2010
Testimonial: "thanks guys&gals i used to work on all this stuff as you get older you tend to lasp onse in awhile. thanks alot mack"
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
What is the proper way to adjust the high low carburetor setting on a Poulan Pro weed eater
Both should be set at 1 and a half turns out to start. Turning the screws out will richen. Turning in will lean. If its hard to start or boggs/ dies when you throttle then its lean- turn the low out another half turn. If it revs up for a minute then slows down richen up the high. At full throttle you still want to hear a bit of a cackle- adjust the high
Jul 08, 2014 | Garden
Camry stalling
Fuel filter,air filter,IAC sensor,Bring up low idle at throttle body is small set screw.
Jun 12, 2013 | Cars & Trucks
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ΒΌ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
While mowing the grass the engine stalls and then catches back and stalls and catches back contuniually. the Murry select riding mower model number 405000x8c.
bad fuel filter, maybe cutting to fast, or grass is to high for what ever setting your at.
example. if grass is more then 10'' high, its not recommended to try and cut it to 3'' in one shot. start with the highest setting, and work it down. hope this helps.......
Sep 22, 2010 | Garden
I need to know the high and low settings on husqvarna35
Turn both jet needles CW to stops (lightly), then turn each screw out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to idle. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
Poulan 2450 wont start
oft
Jan 21, 2009 | Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
