Question about Dell 0Y3740 Keyboard
Pinning a number key back on the keyboard
My number "5" key popped off my Latitude D830 and I can not figure out how to clip it back in.
  • 1,602 Answers
TURN THE KEY OVER AND SEE IF ANY OF THE CONNECTS OR TABS ARE BROKEN. IF NOR THAN FIRMLY PLACE THE KEY PART THE BESAT TO CENTER POSTION AAAAND FIRMLY DEPRESS THE KEY DOWN UNTIL YOU FILL AND HEAR A SNAP, THE KEY WILL WORK PROPERLY AND OKAY, IF YOU DONT FILL YOU CANNOT DO THIS THAN TAKE IT TO A BEST BUY CUSTOMER SERVICE TECH AND LET THEM DO IT AND THEY SHOULDNT CHARGE YOU FOR THE HELP.
RODGANDYSR
Posted on Mar 07, 2009
My keyboard wont light up i have a latitude d830
I was unaware that the keyboard on a Dell 830 was lit.
Feb 02, 2014 | Dell Latitude D830 Notebook
My dell latitude D830 won't boot up back desktop picture
press crtl+alt+del, get in task manager, new task and type 'explorer.exe', your explorer file is not getting started.
Mar 20, 2013 | Dell Latitude D830 Notebook
Hi, I have a Dell Latitude D830. The display was off. I can connect extrenal monitor for current work. Please advise if I need replace display or motherboard ? Thanks Alex
Before replacing anything verify that your laptops display type didn't get changed to VGA out only.
look at your function keys (usually top one or two rows ) and look for the key that has a pc/monitor icon. with the machine powered up and connected to the external monitor press the function (FN button lower left of keyboard) and the video/monitor button at the same time. most laptops have 3 settings:
laptop display only, external display only and laptop and external display. Press the FN/Display button at lease 3 times waiting 3-5 seconds between keystrokes. I have seen this many times where the FN/display button keys are hit inadvertently.
Typically if the motherboard or video card fail the external monitor would not work either.
Jan 04, 2011 | Dell Latitude D830 Notebook
How do I install memory that's under keyboard on d830 latitude
Lift up 1 side of the keyboard cover with a small flat screwdriver.
Remove keyboard cover.
Remve three screws securing the keyboard.
Lift up the keyboard and placed it on the display panel or palm rest, so you can accss the memory slot A. The keyboard is attached to the mboard via a flat ribbon cable.
The memory slot A is located just abve the touch pad buttons.
In order to remove the existing memory module carefully spread latches on both sies of the memory slot.
The memory module will pop up at a 30 degree angle.
Pull the memory module from the slot A by the edges.
Install new ram and put everything back together.
Done!
Sep 10, 2010 | Dell Latitude D830 Laptop Computer PC...
How do enable presentation mode on a Dell Latitude E6400? You have this question/issue on your site, but I am unable to find the solution.
You should see a screen icon on the keyboard, (usually its the F6 or F8 key). Press FN and that key, and that should switch from LCD to External, then to Dual, then back to LCD.
May 24, 2010 | Dell Latitude D830 Notebook
Dell D830 laptop - try to open DVD player get error "This application cannot play this DVD because of the configuration of the output display. Please restart the player." Installed Cyberlink Power DVD DX...
f7
Hi, you may have dual monitors activated which is a possible reason for the dvd not being playable. try holding down the fn key in the bottom corner of your keyboard and then tapping the f7 key. if your screen goes black, tap it again. you are cycling the display options. play around with tapping that key and starting the program. you may also right click the desktop>personalize>display settings, and make sure that your display is 32 bit and utilizing the maximum number of pixels it can. if you are using windows vista basic or business, you may need to download DVD codecs from microsoft or and affiliate's website.
Jan 27, 2010 | Dell Latitude D830 Intel Core 2 Duo T7250...
Spilled Cola on my keyboard
Service Manual for dell latitude D 830 can be downloaded from :
http://support.dell.com/support/edocs/systems/latd830/en/index.htm
in order to remove the keyboard
1. remove the hinge covers and then take the grey strip out where you have the power buttons also
then you will see the 2 screws for the keyboard .
Then take the keyboard out .
rest all the details ar in the manual .
Mar 24, 2009 | Dell Latitude D830 Notebook
Caps lock key broke off
You'll need a new keyboard.
Mar 05, 2009 | Dell Latitude D830 Notebook
B key on my Dell Latitude popped off
Generally, once a key pops off a portable keyboard the keyboard needs to be replaced. It is pretty simple to replace and not too expensive.
Here is an example of a replacement on Ebay:
http://cgi.ebay.com/NEW-KEYBOARD-DELL-8500-500M-Latitude-D505-D600-D800_W0QQitemZ250338315590QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item250338315590&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
To replace the keyboard, just remove the hinge cover, take out the screws for the keyboard and lift the keyboard to release the cable connector.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Dell 0Y3740 Keyboard Logo
76 people viewed this question
Alun Cox
