Question about Air Tools & Compressors
My problem is my stand fan stops rotating and i see a little smoke coming outside.....please solve my problem
    President:
  • 1,922 Answers
Your motor windings are gone,the motor start cap went out first then it tries to start by itself w/o cap and motor runs slow and overheats windings
Posted on Oct 06, 2009
16 Inch Stand Fan with Remote Control (SD10-2) W wont stop roating
Hi Kayla...I have a granddaughter (whom I adore) named Kayla...:). I'm not sure if you found your problem yet, but it sounds like it has something to do with your remote control. If you give me some more information, I might be able to help you better. However, if you're able to turn the fan on and off without the remote control - does that solve your problem. Otherwise, read in your manual (if you got one, or were given this) to see if they have a troubleshooting guide. At least its rotating, cause I usually hear about them when they stop rotating...:) Best of luck, and I hope you found your solution already - otherwise, I'll be more than willing to help you through the process. Take care...Jim
Jun 01, 2014 | Dryers
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Fan out side is not working
Does the compressor come on? do you hear any humming?
Aug 14, 2011 | Carrier 38CKC042 Air Conditioner
There is white smoke that come from the tail pipe and a little every 4 minutes under the hood did that like four time than stop and the fan is not coming on what could these things be
White smoke out of the tail pipe may be an indication of a bad head gasket in the engine. Pull your oil dipstick out and see if the oil looks a little milky.
Nov 09, 2010 | 1996 Oldsmobile Ninety Eight
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Diagnosing a blower that began ticking and then stopped
yes i am havin the same trouble but i have had outside water come in through my fan motor there is a hole in the bottom of the fan houseing and the water comes through there i am now waiting for my fan to stop working all togather and then i will replace it but not before i find the water leak
Aug 11, 2008 | 2006 Chevrolet HHR
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Oct 07, 2007 | GE JSP26 Electric Kitchen Range
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
