Question about Sony KV-32S22 32" TV
Remote quit working after i pressed the reset or code set button
Sony RM-Y135A just stopped working, funtion lights still flash. I think i pressed the reset or code set by mistake and now i cant firge out how to get it to work again.
  • Michael Kruper Mar 07, 2009
    TV on/off, not affecting remote,
    Problem Solver:
  • 10 Answers
Turn off the tv..
Posted on Mar 07, 2009
Necesito configurar un control remoto para TV Sony RM-Y135A
If the Sony remote is the one that came with your Sony TV, try removing the batteries, pushing all the buttons to fix a "stuck" button, reinstalling or replacing the batteries, and testing operation. If no results the remote will have to be replaced.
Apr 19, 2014 | Sony Televison & Video
I need the code for a Sony remote RM-Y135A
Click here to get into Sony support to download the user manual to your remote. Universal remote codes for Sony TVs are: 0128 0013 0002 0071 0380
Aug 23, 2012 | Sony Rmy135a Remote Control
I have a Sylvania 6727DF and need the remote codes for a Sony RM-VLZ620
Hello
Sylvania is not listed with this Sony remote control setup codes. But you can find your device code by the following procedure.
Note
If no operations are performed for 10 seconds while setting, the setting will be canceled, and must be restarted.
1 Power on the device with its power switch.
2 Aim the RM-VLZ620 at the device you want to set.
3 Press and hold SET for more than 3 seconds.
* While keeping SET held down, press the desired Device Select button, then release both buttons.
* The selected Device Select button lights up.
4 Enter 9- 2 - 2.
* The SET indicator flashes three times to indicate that the setting mode has been entered.
* 3 flashes
5 Press and hold => to start searching
6 When the device turns off, release the button.
If you overshoot the required code, you can search for the next or previous code using the =>or <= button.
7 Press (+).
* The SET indicator flashes three times, and the indicators turn off
* To cancel the process
Press SET anytime
Notes
? If all codes have been cycled through once, the SET indicator and selected Device Select button flash once and turn off.
? If the setting is incomplete, the SET indicator flashes once and the indicators turn off.
? If you still cannot operate the device, even after setting the manufacturer's code using the Search function, another code may be available. Repeat the above steps to search for another code that works for most functions of your device.
Jun 29, 2011 | Sylvania Televison & Video
I have a lcd sansui SV-3255LCD tv but the remote had quit on me. can you people help by supplying me with the code for my LCD? And will the code for my LCD work on my sony universal remote RM-AAP013?...
Sansui is built by Japan firm Orion try 135 or 136 four digit try 0135 or 0310
On the remote control, press and hold the RM SET UP button.
  1. While holding down the RM SET UP button, press and release the A/V I/O button.
  2. Release the RM SET UP button.
  3. Press the input (component) button to be controlled. NOTE: To program a television press the TV I/O button.
  4. Press the number buttons to enter the numeric code corresponding to the component and the make of the component to be controlled. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Press the ENTER button.
hope this helps
Mar 28, 2011 | Televison & Video
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need codes that will operate my ONKYO BLUE RAY DV-BD606 player
there is no sulution as far as codes are considered for blu rays. You have to do a manual learning mode for every button.you need to buy a learning remote this is where you point both remotes at each other and press each button to learn it. unfurtunately your sony remote does not have this funtion. i hope this clarifies your problem.
Jan 10, 2009 | Sony RM-V302 Remote Control
"AMP" button on Sony RM-VL 900T stopped responding
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Dec 27, 2008 | Sony RM-VL900 Remote Control
Sony av remote
To reset the remote control to the factory default settings, simultaneously press the POWER , TV/VIDEO , and VOL- buttons. Go here for programming instructions; http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMPP412
Sep 03, 2008 | Sony (RM-SP50) Remote Control
Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
