Question about RCA HD52W58 52" TV
Where is a the fuse in a rca model r52wh74
Wher is the fuse at in a rca modle r52wh74
  • bertavcox Mar 24, 2009
    green power light flashing but tv won't power up. Where are fuses?
On the main power supply board. To get to it you will need to remove the back of the case and locate the power supply board ( follow the power cord to the board ) and it is next to the connector.
BUT, I doubt that is your problem because if the fuse is blown then there would be no lights.
Posted on Mar 31, 2009
Is there a way that anyone can tell me where the fuse panel is on a RCA Model #: R52WH74 television?
There is one fuse on the AC filter board which is where the power cord is located. Just trace the power cord back to where it plugs into the circuit board on the right side when looking in the rear you will see the fuse located right next to where the cord plugs in on that board.
Nov 16, 2011 | RCA Televison & Video
I have a rca Model R52WH74 which the picture resolution is given out. Please tell me what can I do to fix this issue? It look like the picture is in 3D
Jun 25, 2010 | Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model r52wh74
You could get into service mode and set the convergence. The only problem is....RCA decided to remove it from the menu for the R52WH74. It only runs 1 time during the first setup, according to RCA Customer Service. This is the 2nd one I've bougt in 6 years. Enough RCA Garbage!
Dec 02, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
RCA HD52W58 52" TV Logo
458 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
