Question about Apple iPod nano 4th Generation
Ipod connection when i plug my ipod in to my computer it says it has a malfunction and its not reginized. i tried troubleshooting it but that didnt get me anyware. please help!!!!
  • 1 more comment
  • heathurrrr Apr 03, 2009
    i also had the same issue. my ipod was plugged into the computer on itunes and i accidently yanked the cord out. i tried plugging it back it but the ipod wouldn't show up on itunes. the computer says that it is a device with a malfunction that cannot be recognized. i tried pressing the middle and menu button continuously and the sceen went dark, and the apple appeared, but after a few seconds it went back to the normal menu screen.... is there anything else i can do?
  • lizzia_girl May 10, 2009
    I plugged it into the computer today and it said not recognised. It won't connect to itunes and its not located in my computer. Also, because it says connected, it won't switch on or off.
  • Sandizzle May 12, 2009
    My ipod has been working fine then all of a sudden today it says there was a malfunction and it wont work with my itunes anymore. I tried the troubleshooting thing it offers-no help at all. the screen is frozen on my ipod now and just says connected and wont do anything...Please help! The continous pressing of menu and middle button did nothing...
Oki
here
you have to press menu and the middle button and keep pressing it. wait and see
Posted on Mar 15, 2009
My iPod is not recognized by Windows (XP SP3). The message says that "the USB device attached has malfunctioned" the troubleshooter says no driver is present. I have uninstall the mass storge...
Welcome to Fixya. The "the USB device attached has malfunctioned" is a common issue of a usb device that is connected to the computer. If you can still use the ipod properly it seems that there is something that has been detect by windows that is malfunctioning on the iPod when you connect it. There are only 3 possible reasons. First is the cable that you are using and the other one is the port on the ipod where you connect the usb cable and the 3rd is the motherboard needs to be rebooted. You can try to change the usb cable or try to use the steps below and see if you will encounter the same error.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power. First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices! So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
If you are using a laptop you need to remove the battery to drain the power on the motherboard. Please let me know what happen so that we can continue troubleshooting.
If you have questions please let me know. Thanks
Sep 23, 2011 | Apple iPod MA446LL/A MP3 Player
When I try to download music from pc to my ipod, pc says connect
Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
- if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
-Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
1>www.apple.com
2>Click on the tab SUPPORT
3>Select iPod+iTunes
4>Select iPod nano 4 r 5th gen
5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
-if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
Try wit al dese steps.. hope sumthin works out 4 u..
If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
May 26, 2010 | Apple iPod nano
Everytime i plug in my ipod its not showing that it's connected
Okay, don't freak out. What we'll do is systematically check the different points where a problem could be hiding, correct it or eliminate it, and then you can return to your normal iPodding. This could be no big deal so let's check the small stuff first, then we'll test the software.
Before we go ahead and troubleshoot your problem, lets quickly run through this checklist, just to make sure it is not something obvious:
  • Check your connections (USB fully plugged in? iPod connected?).
  • Plug the iPod directly into the computer (don't use a USB hub).
  • Try a different USB port.
  • Use a different cable (ask a friend if you can borrow their USB cable).
  • Remove all the other USB connections (sometimes other USB devices can cause a conflict).
  • Try this:
    • Unplug your iPod
    • Close all programs that are currently running.
    • Plug in your iPod.
    • Open iTunes.
  • Try rebooting the computer
ipod_notmounting_troushoot.gif If any of these steps got your iPod to show up in iTunes, make note of what was causing the problem, then continue to enjoy your iPodding lifestyle.
Aug 10, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My ipod nano blue 4 gb 2nd generation
try giving it a firmware upgrade
dowload it from ur product suppoert area page
Aug 19, 2008 | Apple iPod nano
Computer won't read ipod
I can solve this problem, drop me a comment if you need my assistance.
Jul 23, 2008 | Apple iPod classic MP3 Player
Ipod is Not Being Recognized by Computer
First ipod cables only work on ipod.
Second if you bent the connections (even just one) so that it is not connecting inside your ipod you will need to get that fixed.
You should reboot your computer and try again first though.
Apr 11, 2008 | Apple iPod nano
Computer turning off when iPod plugged in.
First, does this only happen on your computer, or all computers you connect it to? If you have a second computer or a friend who will let you test on their's, then try it on another computer. If it affects it the same way it is most likely the hard drive (since there was a disk error message) or a malfunction in it's logic board. If it works fine on other computers, then I'd try updating the firmware and drivers. Here is a firmware for most ipods. http://drivers.softpedia.com/get/FIRMWARE/Others/Apple-iPod-Firmware-20060628.shtml
Mar 02, 2008 | Apple iPod nano
MY IPOD NANO FROZE!!!!!!!!!
Last night I was trying to play my Ipod but it didnt play. It wouldnt play any song and the timebar didnt move so that also didnt help it to work.
Dec 03, 2007 | Apple iPod mini M9160LL/A MP3 Player
My ipod shuffle usb is not being read by any computers
Never discount the possibility of a simple poor electrical connection (or a busted usb plug on the shuffle - you didnt yank at it, did you?)
Try to swab out the inside of the usb plug on the shuffle.. 99% rubbing alchohol is best. A qtip might fit, if squashed a bit
Mar 14, 2007 | Apple iPod shuffle MP3 Player
Apple iPod nano 4th Generation Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
