I have a speed queen washing machine for 10 years and i never removed the agitator but now water is leaking from it.can someone tell me how i can remove it
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
How do I remove the agitator on my Speed Queen AA4211WE? There's no cap! It all appears to be one piece.
I just did that. Just pull up really hard. Now.. how to get that other thing off to pull the tub, I can't figure out, all bolts are removed.
Jul 27, 2010 | Speed Queen AWS45NW Top Load Washer
Speed queen washing machine mod kaw693 repair manual reqired
do you know where I can obtain a repair manual for my Kleenmaid KAW693 I need to replace the seals and bearings as it leaks a bit of water and makes a screeching noice when agitating. My email address is kerryn12@optusnet.com.au Thank you
Apr 28, 2009 | Speed Queen AWS52NW Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
Feb 02, 2009 | Speed Queen AWS75NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
