Question about Kenmore Refrigerators
Kenmore elite refrigerator/freezer loud banging
Seems to make a loud final bang when what i assume is the compressor cuts off. Theyare sperate units combined to look like one large side by side...not sure which is making the banging
  • 163 Answers
It is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Posted on Mar 07, 2009
Loud Bang bottom freezer Maytag refrigerator
sounds like blown relay in compressor?
Mar 09, 2015 | Maytag Refrigerators
#Amana ABB1921DW, Frige, freezer on the bottom. Fridge is freezing all food, and there is a loud banging inside . Fridge is at the lowest setting. Freezer is fine. Anyone with any ideas or same...
You will need to check the=> 67003410 Damper Control If it is not working properly or blocked by ice from the freezer no mater what setting you choose it is going to get too cold or if closed too hot. Here is a link to how to test the auto damper=> HERE Not sure what the banging is caused by unless the fans are hitting their housings or ice formed around or near the fan blades, Can you tell me where the banging is coming from like freezer or below the refrigerator in the compressor area? Sea Breeze
Sep 04, 2013 | Amana Refrigerators
Loud banging every half hour or so. Loud rumbling as well. Usually the loud rumble starts once the door has been opened
Sounds like a broken mount for your compressor.
You'll need to look in the back of the unit and possibly remove a cover to access it
Being a Kenmore you should be able find most any part you may need by entering the model # at this site
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Jun 01, 2011 | Kenmore Top Freezer Refrigerator
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Refridgerater shuts off with a bang
When you look at the compressor of a refrigerator, what you see is actually just an outer case. The compressor is inside that case, supported on four springs. If you give a compressor a shake (even a new one) you will hear the inner compressor part knock on the outer case. Sometimes, if a spring brakes or gets weak, when the compressor stops running, the momentum will then cause it to strike the outer case, causing a loud knock or two. Most refrigerators will work fine for many years if this condition occurs. It is a bit annoying, but the only fix would be to replace the compressor, which is generally prohibitively expensive if the unit is no longer in warranty. Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 15, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore model 970-224221 upright freezer not working properly. unit made a loud bang during normal operation.
The compressor will make a loud "thump" sound if the motor inside has broken loose.
Jan 10, 2009 | Refrigerators
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Loud banging noise and water leaking
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Dec 12, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Loud banging noise
some popping noise is normal but if it is banging when it stops it needs a new compressor.what has happened is one or more motor mount is broken or weak it could run like this for months or years but it is annoying! if its warranty they have to replace it.
Dec 11, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
279 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
