Question about Magic Chef MCWC30MCG Compact Wine Cooler
Motor very hot; not cooling
We were away for a couple of weeks and didn't notice that the wine was room temp. The motor is hot but the chamber is not being cooled.
    Problem Solver:
  • 10 Answers
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Posted on Mar 07, 2009
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
What does it mean when "LL" shows up in the temp light box? Also the wine fridge was very cold with condensation inside and out. We just got home from a week away and noticed a high whining sound as well.
You may have had a power surge or outage while you were gone. The temp sensor may have failed or the control board may have failed. Either way, the code means that the temp in the frig is not the temp that it is set to be.
Dec 01, 2013 | Haier BC112G Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Hi , our room is getting hot and more hot, it is 35 deg celcious now, how can we set the temp?
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Feb 04, 2011 | Heating & Cooling
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Nobody has answered my question!
check freon and fan motor and maybe your thermostat
Mar 02, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Nov 25, 2008 | U-Line 15WC Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
739 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
