Question about Maytag Neptune MAH5500B Front Load Washer
Dead in the water
On its own between use, the panel went dead, wall plug is fine, cant start it. cant get the top off. Salesman says its the control panel. wants a third of the price of the machine to fix it.
THERE IS SCREWS ON THE BACK SIDE OF THE PANEL, REMOVE THE SCREWS AND PUSH FORWARD A LITTLE WHILE PULLING UP AND IT WILL LAY DOWN RIGHT ON TOP OF MACHINE, THAT IS WHERE I FOUND DIRECTIONS TO ALL THE PROBLEMS I HAVE BEEN HAVING
Posted on Mar 09, 2009
My Danby DWM99W is just dead.
Is the circuit breaker for the wall plug tripped?
Dec 20, 2016 | Danby Washing Machines
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
NN-A774SBBPQ Invertor & Cat-Clean model.
no 3rd fuse as far as i know just the two on the mains pcb and the plug i would test all three fuses again but if the short has gone back up to the control panel them that might be why its not coming back on if it has blown the control pcb it will show up as ablack mark on the pcb sorry cant be nore help its the sort of thing i would need to see as it could be a door micro switch as well gd luck dont forget to unplug the unit
Oct 05, 2009 | Panasonic Microwave Ovens
Nothing on rage works
Open the control panel and check all connections inside. Look for loose/burned/corroded wires and connections. Plug the range back in and use a wooden spoon, move all wires individually with the wooden spoon until a light comes on. Check out whatever the wire goes to for a bad connection.
Jun 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Wt761
The first thing to check here is by opening up the top of your washer. Plug off the mains. Check to see the wires are connected to the inlet valve at the point where the water enters your machine, tighten the wires. Then shut off the wall faucet, unscrew the hoses, check the fine mesh at the machine valve entrance, clean out. Refit the hoses carefully without cross threading, open the wall faucet full to check for leaks; advisable to keep faucet fully open. Check to see that there is no leak at the dispenser end of the pipes. You are done now, try the machine (with the top open, caution)
If there is still no water, just change the inlet water valve, you can do it yourself.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wont turn on
is it plugged into the top plug that is controlled by a wall switch?
Feb 24, 2009 | Canon imageCLASS D880 All-In-One Laser...
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Dead refrigerator.
We weren't able to find a "Reset" button anywhere on the fridge, so I turned it off, unplugged it, waited 24 hours, and plugged it back in. The lights came on and I, then, turned it back on. It's working fine and keeping ice cubes frozen. Whew! That was a relief!
Thanx for your website.
Pat
Nov 15, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Dead Fisher & Paykel GWL11 Washer
Plug off the wall; dismantle & clean out your pump. This is if your filter is clean.
Jun 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
