Question about DeLonghi Heating & Cooling
San marco electric fire keeps cutting out after a couple of minutes, i will switch it off leave it for ten minutes and will come back on and same thing will happen again. does anyone have any idea what part i need to replace.
  • Anonymous Mar 13, 2014
    My mum has one of these and she thinks it is the source of a 'beeping noise' that keeps coming on for an hour or so a couple of times a day (I keep missing it!) - could it be the fire?
    Cheers, Mark
Yeh it does that it runs on a timer, read your manual an maybe you'll understand.
Posted on Aug 06, 2010
Cutting out
Almost sounds like a vacuum lock ("it feels like it running out of fuel"), like the gas tank isn't venting.
Air has to be allowed into the gas tank to replace the fuel leaving it.
Next time it dies, open/take off gas cap and see if it fires up right away, instead of having to wait 10 minutes.
If that works, start looking at the vent lines and see if it's plugged, or a one-way valve isn't working, or the line is pinched.
Dec 30, 2013 | Suzuki GSX-R 600 Motorcycles
PC won't start: Jedi solution
Many times when a customer's PC will not start, though it seems like power is getting to the components (fans are running, etc), I have simply turned off all power, including the power supply off switch if it is so equipped, disconnected all cables to all peripherals and surge protectors and waited a few minutes. Then, I connect everything back up and nine times out of ten she fires right back up and all is well. An electronics technician friend of mine suggested that static charges can build up and somehow keep the pc from starting, and disconnecting everything releases the charge and it works again. I'm not sure if that is exactly why, but I can tell you that it works!
on Apr 14, 2012 | ASUS Computers & Internet
Have a 1985 FXRS Low-glide the ignition spark cuts in and out at start-up. Runs fine after warm up,but if I shut it down and let it sit ten minutes.wont start for a couple minutes till spark- fires while...
What ignition system are you using. Is it points or electronic? Has it been modified? If electronic then cam sensor may be gone. If points then all it can be is wiring assuming points/condensor has been changed or checked. All else then ignition module has failed.
Oct 07, 2013 | Harley Davidson Motorcycles
Honda accord alternator
IF the alternator is not putting out anything. The car will run till the battery is not able to produce enough to fire the ignition, then it will die, It wont restart either. Jumping it will start it for 5 or ten minutes, this is with no warning either.
Apr 26, 2013 | Cars & Trucks
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
Background of San MArcos
If you are looking for images of San Marcos University to set as a desktop background picture, try this link.
May 05, 2011 | Computers & Internet
How do you star a 98 chavy malibu with tha anti theft light on
Here is what you do. make sure the battery is fully charged cause you dont want it to go dead during this process or it wont work. step down on your parking brake pedal and leave it down. this will keep the headlights off during the process so the battery wont go dead. turn the ignition key like you were going to start the car then leave the key in the on position. you have to leave the key in the on position for ten minutes. during the ten minutes you will see the anti theft or security light flashing or the display in the instrument cluster. when the ten minutes are up the security light will go out. once the light goes out attempt to start the car. if it doesnt start turn the key all the way back to the off position count to three then attempt to start the car then leave the key in the on position another ten minutes till the light stops flashing again. sometimes it takes up to three ten minute cycles to reset the antitheft system. so basically you do the same thing three times leaving the key in the on position for ten minutes each time so it will take approximately thirty minutes. sometimes it will work on the first try though.
Oct 31, 2009 | 1998 Chevrolet Malibu
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Heating & Cooling Logo
314 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
