Question about AOC LM729 17" LCD Monitor
AOC 26" LCD 619Fh Problem
I just bought this monitor and hooked it up at the HDMI port on my graphic card. The thing is, i cant get a sharp image... When i turn on the "demo mode" from within the monitors "Color Boost" OSD, the left half of the screen magically becomes perfect while the right half stays kinna blur and unsharp... how to solve this?
Go to "Picture Boost" option in the "OSD window". Then turn on the "Bright Frame" option and after that make the "Frame Size" to 100. That's it now you can get a perfect sharp image...it worked for me.
Posted on Jun 07, 2009
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
I want to connect my Xbox 360 to my aoc f22+ monitor so I bought a hdmi to d-sub cable to plug the Xbox into the monitor as it didn't have a hdmi input. The screen just shows a blank image and the only...
You need a HDMI to DI cable not HDMI to d-sub cable. The sellers that are selling that cable do not tell you that it will only work with special video cards that output analog to the HDMI connector. HDMI is digital and so is DVI so they will adapt to each other. Keep in mind that this is for video only, sound will not work on the monitor because the DVI port does not support sound. You will need to add a set of speakers to the Xbox
Aug 27, 2012 | Computers & Internet
I have an AOC L19WH LCD monitor. I am trying to get sound out of the monitors speakers but am having problems.
I can't find the model number you posted from the AOC website, so its hard to help you.
The only way you can get sound from a monitor is if you plug in the HDMI cable, this means that you need a graphics card with HDMI, very few computers have onboard HDMI.
Monitors that have speakers use HDMI and they need to be plugged into a HDMI port.
If you are using the DVI port, you will NOT get any sound.
You need to post the correct model number or a link to your manual, you also need to post what computer and what graphics card you have.
If you post this info, then someone can help.
The posts above are funny, a PSU has nothing to do with sound.
ODIEBUGS
Apr 05, 2012 | Computers & Internet
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
Hi,i bought an aoc 2243fw2k monitor with dual hdmi ports,n i hav an nvidia geforce 220gt 1gb ddr3,i instaled the drivers n graphic card drivers n kept all the conectins properly,bt i wont get the video in...
http://www.nvidia.com/object/win7-winvista-32bit-285.62-whql-driver.html
this is teh driver you need (windows 7 ) If you need it for windows xp ..you have to select the os first .
Also if you need it for a 64 system select it ..and install it after download.
Use the hdmi for to have a hd image ..and select the correct port in the monitor ..
restart after finish the driver installation .and make the settings
after..Also check the board in device manager to be proper installed (right click on computer icon ..select properties than device manager (for xp select first hardware ) ..and in helist look under display ..and the driver should be present by name and not with yellow color and exclamation or ask sign ..
Also it may need some settings in the video card ..so open the settings for video card in control panel and look up for what should be set ..specially related with the secondary monitor and the hd mode..
Dec 15, 2011 | Computers & Internet
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
Need a new 26in tv scren as old one is cracked and how much will it cost me to fix it
LCD panels are very expensive when bought as a part.. often much more then the original TV.. especially when its a few years old. You can have them repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Dec 27, 2009 | AOC 26IN LCD 10 000:1 619FH Glossy Blk Dvi...
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
AOC LM729 17" LCD Monitor Logo
735 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
