Question about Zenith P42W46X 42 in. Plasma EDTV
Picture flickers in and out. I tap on the tv and it may stop for hrs or minutes. It seems to stabilize after I rap the case at the front "Z" decal emblem on the front of tv . I have checked and it does this with all inputs. It sometimes does this so bad its like a pshycadelic dance club in dark room from the flashing, but then can hit it with my fist slightly and problem stops
  • 245 Answers
Check ur antenna connection ....also all other connection u have connected....make sure they are have a firm connection...if problem stays faulty get ur tv to repair shop......
it looks to me u have a loose connection inside ur tv what needs attention from a technical repair person....with tapping u will make the fault even worse in the long run
Posted on Mar 07, 2009
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
Jul 20, 2009 | Sony Televison & Video
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Zenith P42W46X 42 in. Plasma EDTV Logo
178 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
