Question about Tissot T33.1.588.51 T-Touch Dial
Can't set date. Did set time
Not sure what function makes the date change. Thanks.
  • 2,334 Answers
Paste this link into your browser and use interactive tabs to sort out everything:
http://www.t-touch.com/flash.html?20090307051010
Do not forget to rate, please.
Posted on Mar 07, 2009
How make the hour(time )setting
Both the time and the date are set via the winding stem. To set the date, pull out the stem to the first "click" and than turn it and watch as the numbers change. To set the time, pull out to the second "click" and then turn to set the time. Some watches have a screw-down stem crown. If yours does, simply unscrew it by rotating in a counter-clockwise direction until it releases and pops out slightly.
If your watch has a day calendar function it is important to not attempt to set the hour or change the date if the current reading is between 10 PM and 2 AM. If you do, there may be some damage to the advance function responsible for moving the calendar.
The easiest way to set the time and day is to advance the date to the day before the current one. Then pull out the stem and advance the hours until the date clicks over. That is midnight and as long as the current time isn't between 10 PM and 2 AM, you're good to go.
Jul 02, 2011 | Watches
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
Just bought a Lacoste watch,and I am puzzled why they stress the importance of not changing the date between the hours of 11.45pm and 2.00am?.
If you change the date between those hours, and the watch is set for the correct time, it may automatically roll the date forward yet again. It could mess up the internal mechanism for changing the date. The date starts to change around 11:45 PM and can take a good long while for it to fully "engage" the new date, which is why they say to wait til 2:00 AM. The internal mechanics that change the date are very sensitive. If you force it to change the date while it is automatically trying to change it, it can off-set the little gears and they may not function correctly in the future. So just make sure the time on the watch is not between 11:45 PM and 2:00 AM when you change it. The best thing to do is to change the date to the day PRIOR to the day you want (for example today is the 21st, set it to the 20th, then advance the hour / minute hands past midnight so it automatically rolls into the 21st, and then you will know if you are on AM or PM).....
But just avoid setting it between 11:45 PM and 2:00 AM as they mention.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 21, 2010 | Watches
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 | Watches
Can you set the time going counter clockwise on a watch
yes, you can set the time counter-clockwise on a watch. The only difficulty that may arise from this is making sure the date window (if you have one) syncs up; but a 1 hr change for time change will not make a difference. For best results start setting with your day window reading 1 day before the current day and begin turning clockwise. Right when the day/date changes the watch is reading 12am(midnight); set accordingly.
Nov 03, 2009 | Bulova Watch
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
I can't set the date on my new citizen's eco drive BM8080-59A. I don't know if I'm doing it wrong or if the date setting function is broken. I have tried to change the date by pulling the winder to the...
Yes that is ok its right by pulling the crown winder in the mid level or half level,that is for calendar date.To check if function is ok or broken,just pull full the crown and set the time,see if the calendar date is changing or moving.Then if moving then its ok,the next step you do set is the calendar date,by pulling the crown half pull,then turn the crown counterclockwise for date and for the day turn clockwise.Feel free to post whatever the result of the setting...
Hope it may helps you;
Regards,
VOTIT
Sep 23, 2008 | Citizen Watches
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
Aug 10, 2007 | Luminox Navy SEAL Dive 3103 Wrist Watch
Tissot T33.1.588.51 T-Touch Dial Logo
311 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
