Question about Logitech Video Game Consoles & Games
How do I connect it to play the game if it is already plugged in?
My joystick won't work. On Flight Simulator it tells me when I click calibrate, it says it is not connected but it is plugged in
One possible solution is simply to unplug the USB connection and then plug it back in.
Posted on Mar 09, 2009
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
Mar 15, 2017 | Logitech Extreme 3D Pro Joystick
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
Feb 09, 2009 | Saitek Aviator AV8R Joystick
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Attach 3 joystick not working with vista
Joystick installed& calibrated but won't work with combat flight simulator.
Dec 23, 2007 | Logitech Attack 3 Joystick
Video Game Consoles & Games Logo
271 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
