Question about Zanussi TD4112W Electric Dryer
How to access the motor in a zanussi td524 tumble dryer ?
My Zanussi TD524 tumble dryer has been making a noise for a while, and now has almost stopped turning. I have successfully replaced the rear bearing which was very worn, but I think I need to take a look at the motor and belt area, but how can I gain access ? I've taken 2 screws out of the base, but do I remove the base or do I need remove a side panel please ? And how ?
Many thanks for any help here.
Wayne
hards327
  • 30 Answers
SOURCE: Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Posted on Mar 17, 2008
SOURCE: Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Posted on Jun 28, 2008
AlmostBob
  • 550 Answers
SOURCE: zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Posted on Aug 28, 2008
kakee
  • 1269 Answers
SOURCE: Zanussi TC7114W Tumble Dryer manual
Can you please tell us what specific problem are you experiencing with your unit? Or what specific information do you need from the manual.? Thanks!
Posted on Sep 22, 2008
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
How to repair a zanussi condenser tumble dryer belt
Access from the rear panel to drive belt:
- Remove the worktop
- Remove the side panels
- Remove the rear panel cover
- Remove the motor unit
Dado
Oct 03, 2014 | Zanussi TC7102W Electric Dryer
Our Zanussi condenser dryer, trips the house circuit breaker, at change of tumbling direction
I myself would say you have a bad Motor.Something in that motor is not working correctly.
Nov 20, 2010 | Zanussi TC7102W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Mar 14, 2008 | Zanussi TC7102W Electric Dryer
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Zanussi TD4112W Electric Dryer Logo
161 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
