Question about Philips 55PP9401 55" Rear Projection Television
Partial convergence problem
Blue beam sagging at top of picture. Bottom of picture OK.
  • Anonymous Mar 14, 2009
    Blue line starts to sags from upper-right and increases throught the upper-center of screen then increasingly increases apex and it goes back up to the upper-left. Lettering also sags down and left. Blue showding lower than initial objects.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a Partial convergence problem - 2c07611.pnglem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
PictPartial convergence problem - 578ba6c.jpga set that needs the fluid changed.
TV set after fluid chaPartial convergence problem - 2c07611.pngr />65af323.jpg
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
We have the same thing, had Sears TV repairman look at the set. He said it was convergence and that it would cost over $500.00 to replace the parts. And he charged $91.00 for the service call. Needless to say, we did not have him repair it, that's why I'm online now trying to figure something out.
Posted on Mar 26, 2009
Intermittent blue streak on the right side of the screen.
amikeq,
You may be experiencing the beginings of a failing convergence system. To align the beam there are two ICs which take the stored positions, set by you during a convergence alignment, and move the beams to line up on the green beam for a good picture. When the ICs fail your set will look 3D but in your case you may just be seeing a partial and intermittent failure exposing the blue beam momentarily. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains all this and how to repair the unit as well as where to get the parts at the best price.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Feb 24, 2011 | Hitachi 43FWX20B 43" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Greenish colors, and sagging screen picture
Ur tv have a problem known as a "CONVERGENCE" problems.The convergence board the 2 STK covergence ICS and some or all it supporting resistors are dead.All these parts must be replaced to get the convergence to conform once again,to produce a solid good picture.The tv shop should charge u for this job,for $300-350 for parts and labors.
May 21, 2010 | Philips Magnavox 51MP392H Rear Projection...
Hatachi TV. color saggging. Blue and yellow sagging on picture
I would say that you are having convergance problems need to know the model number of the set which is on the back of the tv then might be able to help better. Is there a bow in the colors. Like the red or blue.
Mar 01, 2009 | Televison & Video
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
297 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
