Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Had a power outage and the display panel stopped working.
  • 700 Answers
Take off the backside panel and on the right hand side theres a box where aall the wires go into. remaove it and you will see where theres a fuse on the circuit board. look at it and if its not blown then you may have to ovder a new bboard.
Posted on Mar 27, 2009
I have a whirlpool gold fridge and its flashing the po code why and how do I make it stop
PO stands for Power Outage. The fridge lost power for some reason. On my fridge I just hit "acknowledge" and it goes away. I don't own a whirlpool. Here's a page that lists different instructions for multiple different fridges in order to reset everything and turn off the PO light. http://removeandreplace.com/2016/02/02/refrigerator-display-panel-is-blank-not-working-how-to-reset/
Refrigerator Display Panel Is Blank Not Working How To Reset
Nov 15, 2016 | Whirlpool Refrigerators
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
After power outage ice maker in rf4287hars stopped working,display is dimmed on off ice stopped working any advice
have an fridge technician check it out as it sounds like a control board problem from a spike that occurred after the power outage
Apr 08, 2015 | Refrigerators
We had a power outage and our ice maker just stopped working. Can it be fixed? thanks
If there was a power surge associated with the outage, maybe not.
Does the display still light up?
Dec 01, 2014 | Emerson Portable Ice Maker
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Refrigerators Logo
119 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
