Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hayward H100 gas heater Noise
Just started the spa for the spring and the heater when running is making a loud "cracking" noise. Almost sounds like gears getting stripped off. Its loud enough that it actually shakes the heater each time. I've looked under the blower and nothing there. I thought it might be ice in the tubes but after several days its still there. Its definitely in the tube area or below, not coming from the blower. I can feel it in the pipes each time it "cracks". And only happens with heater running. Any ideas? This heater is only about 8mos. old.
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: Loud noises, shaking, visible white powder in chlorinator
Stop using the heater immediately. You are boiling the water inside and this can lead to a dangerous situation if a limit switch fails to act in time.
You will likely find the diverter in the inlet side of the heater is broken. You are looking for a stainless steel plate in the water path. If you can move it by hand, it is broke. It is not replaceable and requires a new heat exchanger assembly to repair it.
Your part number is IDXHXA1101. We sell it as will most pool dealers. If you would like a quote, contact us at www.arrowmotor.net
Posted on Jun 16, 2009
app_3rp12317
See this page:https://sites.google.com/site/haywardpoolheater/
For info about the part that breaks and how to fix it. YMMV.
Posted on Jan 06, 2012
Replaced a H100 Hayward pool heater with a H2101Heater.New heater runs 4 about 5 min. Then shuts off including pilot. Filter is clean .getting plenty of water pressure. Gas line has no leaks. What's the...
check to see if gas pressure is correct sounds like too small a gas line or meter with pilot going out shows you are draining gas line you have doubled your gas usage
Jul 08, 2014 | Pool & Spa
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Hayward h250 making a banging noise
low water flow if filter ok check manual bypass and return valves open
Apr 03, 2013 | Hayward Pool & Spa
When the burners ignite, within one minute it starts making a loud banging noise and then the HS code comes on and it shuts down. the noise continues for about 15 to 30 seconds after the burners shut...
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Jul 18, 2011 | Hayward H-series Electronic Gas Pool...
I have a H100ID1 natural gas heater. For the past 2 weeks it has been heating the water but making a loud banging noise and shaking the whole heater. It stopped making the noise and won't heat the water....
Is it leaking? Has anything shaken loose inside? If you can get it to light the cause and fix for the banging and shaking is here: https://sites.google.com/site/haywardpoolheater/
Takes about 30 minute and you are done, but you have to figure out what else has gone wrong to stop it lighting
Jul 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Jun 16, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
214 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
