Question about Toshiba Satellite A205-S5879 Laptop
Sound problems i had plug an rca plug from computer to amplifier to play music but i think i had plug it in an wrong outlet and the sound from the computer is not there how.how can i fix this?
  • CampinFamily May 11, 2010
    did u use a plug that was one end a rca end and the toerh like a headphone jack? what are u using for an amp?
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Tip
Connecting your computer to an amplifier to play music
Do you want to connect your computer to a amplifier or surround sound, and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. Select "CD" on your amp if you pluged it into the CD channel, and there you go
on Dec 02, 2009 | Audio Players & Recorders
When playing a dvd you get all sound except speech
Maybe you have a wrong connection if you are using RCA jack check the red and white lines..If you are using HDMI try to reset the connector...
I think there's missing left or right lines of sounds of you amplifier..the possible problems audio IC circuit,wrong/loose connection..
Hope it helps...
Jan 18, 2012 | Televison & Video
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
Amplifier when i plug the rca cables from the radio to amp the subwoofer is jumping and going out of control with no music playing
Make sure the amplifier is properly grounded. If the ground is good, hook an ipod up to the rca's to test.
If the problem goes away, you may have a problem with the headunit. If the problem remains there may be something wrong with the amp.
Feb 28, 2011 | Car Audio & Video
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
How do I connect to computer for music?
Please clarrify? Do you want to connect your computer to a amplifier and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. And there you go
Aug 01, 2009 | Technics SA-EX400 Receiver
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Mar 07, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
Toshiba Satellite A205-S5879 Laptop Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
