Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-27FS200 bright horizontal line problem
CRT TV has no picture (black) on the top 1/4 of screen, a thin very bright (compressed?) band/line underneath, then the picture is normal below this line. Any ideas what this is? Is this the vertical output ic? Worth getting fixed? May consider upgrade to HDTV instead if the fix will be costly.
  • 666 Answers
Try to replace all filter capacitor on vertical section area that can solve your problem.
Posted on Apr 03, 2010
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Sony trinitron no controller ?'s
there,s some button hiden inside the tc. so ,you need to open it adust the brightness..but ,if your tv is too dark change the resistor value 680K at the CRT board . CRT board is a circuit that attach to the picture tube.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Picture keeps turning off with volume still on.
you have a problem with one of the following circuits: video amplifier, ABL (automatic brightness limiting) circuit, crt circuit or in horizontal deflection and high voltage circuits. probably a leaky component that when it get warm it it looses its function or maybe a cold solder. but if u do not know these stuffs better have it check by a qualified service technician.
Jan 08, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
171 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
