Question about ASUS P5PE-VM Motherboard
PC Device Manager will not find Network drivers
ASUS P5P800 motherboard. Found ethernet driver online and copied zipfile to PC via USB-stick. Extracted, ran, saw copied drivers in ".../OPTIONS/CABS", but Device Manager, even with manually pointing to folder, says drivers not found. Checked motherboard with CPU-Z confirmed P5P800. Why can't I install these drivers? Am I copying wrong ones? Downloaded 8110c.zip and RTL8100c.zip.
  • 62 Answers
Try this site. I don't know what your OS is
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Mar 07, 2009
NO DRIVER asus cuv4x free request
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
May 28, 2011 | VIA ASUS CUV4X Socket 370 Apollo Pro 133Z...
I do not have the cd for the asus p5p800 and the ETEHERNET network card drivers are not installed so the internet does not work. What can i do to install the missing drivers for the internet to...
Hi There,
You have not specified your operating system do I'm directing you to the Windows XP Driver Download site for your motherboard. If you are using a different system, choose it from the OS Dropdown window just above the lsit of drivers.
Download the LAN driver and either burn it to a CD or copy to a USB flash drive and then install the driver to the Asus board.
http://support.asus.com/Download.aspx?SLanguage=en&m=P5P800S&p=1&s=22
Regards,
Selk
Apr 23, 2011 | ASUS P5P800S Motherboard
My ASUS M2N SLI onboard LAN connection is not working, I do not have an Ethernet Controller in device manager, and there is no drivers that i can find online to solve this issue. I just re installed...
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-
hope this helps
Mar 22, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No ethernet i dont have driver
Access the web-site of the manufacturer of your network-card (or the manufacturer of the motherboard).
Enter the model-number of your network-card (or the model-number of your motherboard).
Do a search on their "support" pages for device-drivers for your Operating System (XP? 7?)
Download the device-driver, and copy it to a USB memory-stick.
Move the memory-stick to your "not-connected" computer, and install the device-driver.
Mar 17, 2011 | Computers & Internet
Sir ,i format my pc yesterday with xp.i installed all the drivers but lan driver can't work.that's why i m unable to access internet. in device manager Ethernet port had yellow question mark. please tell...
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
a yellow? means you need to install/update driver right click to install driver
hope this helps
Oct 23, 2010 | ASUS P5RD1-VM Motherboard
Ethernet controller misssing
I assume your referring to the driver. You can get that HERE.
Thanks for asking FixYa.
Mark
Mar 02, 2010 | ASUS P5V800-MX Motherboard
Network driver of asus mother board
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
There u go!
The drivers you need for that ethernet on that board is Realtek RTL8100C Ethernet Device Driver V5.621.304.2005
You will find them on that site above, download and instal them
Good luck
Nic
Mar 03, 2009 | ASUS P5GL-MX Motherboard
Looking for a compatible Driver for my Ethernet connection
Open up device manager> double click on the unknown device> go to the details tab> in the drop down choose hardware id> google the alpha numeric code on the first row before the & symbol (ex- PCI\VEN_14E4)
That will give you the make of the ethernet adapter you have on the pc. Once you have it installed you can patch up the wireless as it works on the network adaptor base which generates the ip address.
Hit me again if this dosent do the trick.
Feb 18, 2009 | ASUS M2V Motherboard
No internet connection
Have to reinstall ethernet driver. Need to use a usb wireless to get online, then choose search online for driver, or right click the ethernet adapter in device manager and choose device ID and search for driver on another computer and then install it on yours.
Dec 20, 2008 | Motorola Mobility 17235 Network Adapter
How do I down load ethernet controller, PCI Device, SM Bus Controller, video Controller (VGA Compatible) & other devices driver
if you want to download from the same PC then you cant as the Ethernet driver will not be installed ..
if it is installed then you can download ....
check it in the
control panel>system(switch to classic view in case of XP)> hardware>device manager
in device manager go to network adapters there if the Ethernet driver is installed then you will be displayed there (if the driver is not installed then you will not see that network adapters also)
if it is not installed then you must download the Ethernet driver from some where else to your system from your manufacture(motherboard or chipset manufacture) website (if it is intel then http://downloadcenter.intel.com in this website you can search it & download)
if you have the Ethernet driver installed then you can download from your system only the other drivers from the manufacture website ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 04, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
168 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
