Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark 2500 printer paper gets stuck and won't print
We have a Lexmark 2500 printer/scanner and it won'tprint the paper gets stuck it pulls thesheets on an angle no matterwhat I do Help I have the same problem, I don't see anything stuck on the left side.
    Sergeant:
  • 254 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Mar 07, 2009
I have Lexmark p4350 I can not copy, and show error 2200
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
Sep 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
Lexmark 2500 printer jam. How do I open hte back access panel
Pull it out with a pair of tweezers and then
clean the rollers from where the paper goes in.
clean the carriage rod(metallic rod along which cartridges move)with alcohol.
If this does not work that means that your pick assembly of your printer is dyiing
May 29, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 2500 Series printer does not work properly.
my printer does not print, but tells me i have prints pending
Sep 13, 2008 | Lexmark X2500 All-In-One Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Printer problem
Samsung 4100 laser printer, scanner, copier
The paper gets stuck in the roller and is not drawn up to the drum. The beginning of the problem started when the paper was never pulled from the drawer. When I open the paper drawer after a Paper Jam error, the paper is bent backward but still detached. Now it is drawn in but sticks.....margoa
Oct 16, 2007 | Office Equipment & Supplies
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
Lexmark X5470 All-In-One InkJet Printer Logo
206 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
