Question about Briggs & Stratton Garden
Voltage whats the voltage for an mtd 12.5 l/c quite
  • brocket Mar 25, 2009
    well first i did not say i was going ta shoot the messenger an also i would not try ta waste my time to find the person
    i havent rated the solution yet because i havent tryed it yet
    so back off and just wait
    ill get back ta ya later
I have a MTD mower 13ad771g731, The lights suddenly quit working. Is there a fuse or something I'm missing? Rod
Check for loose connections/blown bulbs.
If still a problem obtain a volt/ohm meter and trace-out the circuits.
MTD is a good mower.
Jun 03, 2017 | Mtd Garden
2007 Ford Explorer horn quit working?
suggest checking if 12 volts goes to horn wire at horn end when horn pressed from inside vehicle. A 12 Volt probe {google it} can be a cheap checking tool for this.
If 12v volts is switched when button is pressed {could be earth being switched if it is then place probe on constant 12 volts and negative lead on switched earth wire} then the horn itself is faulty.
If no voltage switched then horn relay needs to be checked. check if voltage at horn relay coil contact when button pressed.
if yes then relay may be faulty. if no then horn switch could be faulty.
you can check switched voltage also at horn relay switched contact when relay plugged in. To see if relay is doing what it is meant to do
Jan 16, 2017 | 2007 Ford Explorer
My mtd mower with 15.5 hp engine starts and runs for 5 to 10 minutes and quits. It will usually restart with the choke on and run for a few minutes more and quit again. It will finally not restart.
More than likely a carb problem. What kind of fuel you use makes a difference. If ethanol, causes corrosion inside carb. Or maybe something easy as air filter.
Jun 03, 2016 | Mtd Garden
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
Mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
What is the secondary voltage of power transformer
The schematics do not show the actual voltage.
From the design, the phantom power secpndary should be around 35 to 45 volts AC.
The 16 volt supplies would require a secondary winding that will be around 26 to 32 volts center tapped.
Transformers are quite reliable and unless a voltage is missing, the transformer is likely OK.
The most suspect items are the electrolytic filter caps if the voltage is not the design 16 plus and minus values.
Jun 16, 2010 | Mackie 1202vlz3 12 Channel Mixer
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Mtd riding mower model 13AT688H731 B&S 21HP
Did you change the voltage regulator???
Apr 20, 2009 | Garden
Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Dec 23, 2008 | Craftsman Garden
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
