Question about VillaWare 5785 Smoothee Bar Work Top Blender
Leaking fron the blade assembly
Looks like the seal has broken under the blade. Where can I get parts in Canada
    Problem Solver:
  • 15 Answers
HELLO
there are two possible solutions
1 change seal or 2 change seal and blades in order to improve the life or your blender.
bye
j roman.
Posted on Mar 07, 2009
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Blade assembly broke, the part that fits into the motor and turns the blades.
Dear Vicki,
Fixya does not have any parts for anything.
We are a problem solving service, we answer questions only.
Please tell us your make, model, and serial; number for your blender.
Also, type the manufacturer & model information into your computer search engine, and see who sells part for you in Canada.
Know that some blenders cannot be repaired, unless they are quite old, and then sometimes the parts are no longer available.
God bless your efforts.
May 12, 2016 | Blenders
Ksb555
If you have the glass jar then purchase either a new rubber seal for the blade to jar fitment or replace the blade assembly, it will be one or the other. If you have plastic beaker then get a new beaker, it is sold as a single assembly.
Nov 29, 2013 | KitchenAid Blenders
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Leaking blender jar
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
Hi I've got an old Waring 38BL31 which is leaking underneath - looks like it might be a washer problem, but I can't unscrew the blade - anyone know what the trick is - or anywhere that repairs these?...
Hi!! It sounds like the rubber seal is busted, there is not real trick to removing the blade assembly. It will be easier if you have a belt wrench, it looks like the oil filter wrench but with a wide rubber belt instead. Available at most auto parts stores. If not available, just have to apply enough force to unscrew it. Having a friend will help, one holds, one twists. It unscrews counterclockwise.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | Waring 700G Work Top Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
VillaWare 5785 Smoothee Bar Work Top Blender Logo
333 people viewed this question
Top VillaWare Blenders Experts
Steve
Andrew Taylor
Andrew Taylor
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
