Question about Dell Wireless Keyboard Optical Mouse w0147
Keys dont work on inital sign in screen to windows.
  • 1,602 Answers
THE KB BOARD NEEDS TO BE SERVICED, BY REMOVING THE SCREWS OR SNAP CLIPS THAT HOLD THE KB TOGETHER, CLEAN THE CURCIUT BOARD OR PLASTIC FILM WITH SOME ACOLAHOL AND LENT FREE TOWEL,
USE A CAN OF COMPRESSED AIR TO REMOVE THE DIRT FROM THE KEY SWITCHS.
PUT IT BACK TOGETHER,
GO INGO CONTROL PANEL OPEN DEVICE MANAGER, GO DOWN TO KEYBOARD AND CHECK FOR ANY TYPE OF UPDATES OR AND CHANGES TO THE PROGRAM.
IF YOU CAN FIND THE KEYBOARD TEST THAN TEST THE KEYBOARD TO MAKE SURE ALL KEYS ARE WORKING PROPERLY.
RODGANDYSR
Posted on Mar 07, 2009
Why the f8 key dont work in my pc?
What type of computer ?
What are you trying to do ?
Enter safe mode ?
Because of the small amount of space available, many smaller-screened Dell laptops come with a special key known as the "Function," or "Fn" key. The purpose of this key is to double the functions of multiple keys, most commonly the F1 through F12 keys. On some Dell laptops, the F1 through F12 keys are locked from use to give way to more commonly accessed commands and program shortcuts. However, unlocking an "F" key, such as F8, is not difficult.
Press and hold the "Fn" key on your laptop's keyboard. This key will usually be shaded blue and is located in the bottom row. Press the F8 key on your keyboard while still holding the "Fn" key. This will have unlocked the F8 key. Repeat steps 1 and 2 as necessary to unlock any other "F" keys you wish to use.
Apr 11, 2013 | NexxTech NPCINIC Network Adapter
The character keys and numeral keys dont print only make a noice when pressed
From your query I interprete as they key is not displayed in the screen. First check with the external usb keyboard. If the external keyboard is also not working, please check the keyboard layout in the control panel regional settings. If the external keyboard is working well, change the laptop keyboard.
Nov 13, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
My top row of buttons on my dell keyboard is not working. the calculator button and other buttons? weird any ideas?
It says that the drivers for your keyboard is not installed...
you need to Install the drivers that came along with the Keyboard...
If it doesnt comes with a cd search in dell site and download the drivers...
This happens because, the default drivers for keyboard will be present in the database of windows, so you wont be facing any issues in using the keys...
But for using the special keys, u need to have drivers...
Dec 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
Apr 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Dell inspiron keyboard issue that resulted in other problems
If u have your windows xp disc, go to start-run- and type sfc /SCANNOW. It will screen your computer for missing or damaged files, registry and etc... It has fixed about every problem I've have. This is way better than re-installing windows, u lose nothing.
Oct 17, 2009 | Dell 0Y3740 Keyboard
Dell Inspiron 6000 keystroke ''blip'' setting
Kids :) To solve your problem first you need to find out if there is any key that is broken or loose. What you could do is 1) turn off the laptop and wipe the keyboard hardly with a towel to release one of those broken keys. 2) if this doesnt work, you need to unplug external keyboard, and then goto start-> right My Computer -> Manage -> device manager -> keyboards -> rightclick standard keyboard and disable it.
Now put in your external keyboard and test your keyboard. Dont worry your mouse is still working and you can enable your onboard keyboard again. Try this and let me know if your problem is solved or detected. If your external keyboard works, i guess there is a problem with your onboard keyboard. you would require to service it. cheers.
Sep 14, 2009 | Dell Computers & Internet
Keys 8ik,<, dont work most of the time have to
Pry the keys out with a flat blade screw driver and check that there is no mess/spillage underneath, clean with a solvent if necessary.
The keys will push back in with a good click after you have finished cleaning.
Jul 07, 2009 | Dell 0Y3740 Keyboard
Certain letters are not working
When keys go faulty the entire keypad needs replacing. You can't replace individual keys. I would suggest contacting dell and ordering a new keyboard, it's an easy fix: http://www.essortment.com/articles/install-replacement-keyboard-dell-inspiron_102151.htm
If you need to purchase one, I did locate: http://yallstore.com/laptop-keyboard-replacement-for-dell-inspiron-1525-p-4228.html For $16
May 23, 2009 | Computers & Internet
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Dell Wireless Keyboard Optical Mouse w0147 Logo
341 people viewed this question
Alun Cox
