Question about Apple iPhone Smartphone
Whole touch pad will not work
The phone will ring recieve messages but can't use touch pad. I can use the slider bar to turn off that is the only thing
    Scholar:
  • 53 Answers
If you bring it to the apple store, they will basically replace the phone for you if they determine it defect not associated with getting wet, and the item is still under warranty...they may replace it at no charge.
If it has not gotten wet, you should try to do a total reset via itunes.  Connect your phone to your computer. launch items. When phone icon appears, chose the restore option.... The whole phone will be backed up, erased and restored to the original manufactures condition.  then it will allow you to add any thing you had back to it from the backup...
This should fix the problem if its just a software issue.
If this doesn't work, bring it to the apple store.
Hope this helps.  Let me know how it all turns out.
~enov8
Posted on Mar 08, 2009
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
The touch screen does not work. I can see the background picture but it doesn't recognize any touch command. It won"t turn off either. If I click the lock button It turns black then turns itself on again.
My phone suffered the same symptoms, i was able to fix it by turning it off and on, waiting for the verizon word to animate, plugging it into a wall charger and I was then able to use the slider bar to unlock my phone, I was unable to select anything else on the phone so i closed it and used the qwerty keyboard to get to my touch settings menu, where i selected calibrate and followed the steps it told me to in order to calibrate my phone, I had to repeat the whole process several times before my phone was back to 100% hopes this helps.
Jul 03, 2010 | LG enV VX9900 Cellular Phone
The touch pad on my laptop will not sroll through pages vertically using the slider bar to the right of the touch pad
First check if your drivers are up to date.If they are, I guess the problem is a hardware problem.Just try it and give me the feedback
Apr 26, 2010 | HP Pavilion DV6500Z Notebook
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
My phone makes the proper sounds to notify text messages and other alerts, but does NOT make any noise or vibrate upon receiving an incoming call. It appears to be set up to ring, but it does not!!!Can you...
click the volume button on the side of the phone then use the touch screen to slide the reciever slider to your preferred level then test it by calling.
Feb 09, 2010 | Palm Treo Pro Smartphone
Problem with bottom half of screen
have to tried to update it to the current firmware
Dec 13, 2008 | Apple iPhone Smartphone
Need to unlock my NIKI100
i think this is service provider error. u call ur service provider then inform this issu. they give some solution to u.
Jul 09, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
No incoming calls
what you can do is a master reset and master clear on the phone.
May 06, 2008 | Motorola Mobility W375 Cellular Phone
Touch pad not working
you may need a new keypad flex - but the chocolate is a touchy phone and usually if the keypad flex is going the slider flex is next - the new shiine is built better
Jan 18, 2008 | LG KG800 Cellular Phone
My picture messaging aint working
I am having the same problem with mine and I am with Alltel and they have no clue
Nov 08, 2007 | Kyocera Slider Cellular Phone
Apple iPhone Smartphone Logo
26 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
