Question about LG WM-2277HW Front Load Washer
No water inflow
No inflow of water into mashine
    Sergeant:
    Champion:
  • 245 Answers
Make sure door is closed...also check water input hose and when u turn on the machine the lights are on telling you machine is ready,,,,,if this does not solve the problem call LG customer help and service
Posted on Mar 07, 2009
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
Water inflow
The problem is Water Inlet Valve.. If u replace the valve your problem will solve.. Dont waste your money to any other spares.
Sep 26, 2017 | LG Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Water comes out from the bottom of the mashine
Pressure switch failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Programmes in washing mashine Eurotech FL 807 are really long (very old washer?) I want to run an empty mashine on 90 degrees (C) to clean it, can I combine hot water with a shorter programme although the...
yes - there is no thermostat to tell it the water is warm - go for it.
Jan 20, 2009 | Washing Machines
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Dec 17, 2008 | Bosch SHU3305 Dishwasher
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
