Question about Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook
Acer Travelmate 4650 cuts off unexpectedly????
Without prompting, my computer cuts off as if too hot. I have it on a stand and it should not be overheating. Any ideas???
  • RanOver May 24, 2009
    I'm using XP but it also cuts off unexpectedly. I tried the hard-drive in another machine same unexpected shut offs
    Sergeant:
    Champion:
  • 245 Answers
Add a desktop fan next to ur pc this will cool ur pc down ....if problem still happened call ACER costumer help
Posted on Mar 07, 2009
Cannot connect to bt intrnet as wireless network adapter will not recognise isp
You got a conflict on your DNS protocol you need to go into your 'command prompt' settings (right click start and click on command prompt ) and enter 'clear DNS' and see if that works.
Feb 02, 2018 | Acer TravelMate 290LCi Notebook
How do i do a system rebuild on a acer travelmate 2410 series 2413NWMLi , the <alt> <f10> does not bring anything up
If your computer does not have a hidden partition for OS recovery, a recovery CD will be required in order to recover the Operating System using Acer Recovery Media.
Order the Recovery Media from Acer https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 17, 2011 | Acer TravelMate 2300 Notebook
How to format c drive for a Acer travelmate c110 from command prompt
You can't format a computer from the command prompt. the only way to format a hard drive is to get the disk for the operating system. put the disk in the computer then restart the computer. when the computer is starting up at the bottom of the screen will be some commands, one of the commands will to boot from disk. select this option. they the computer will take you through a bunch of screens asking whether or not you want to do this because formatting your hard drive will erase everything on your computer. once you say yes to all these screens you computer will start formatting.
I hope this information was helpful, if you have any comments or questions reply to this post and i will help as much as possible
Nov 10, 2010 | Acer TravelMate C110 Tablet PC
My acer travelmate 4650 screen has broken, i bought a 4600 as a replacement with it being the same size screen is it possible to use this or not, the cable and the inverter are different. please help
Most replacement panels do not come with the inverter. If the two LCD panels are the same size and type (ie: xga). You should be able to remove the inverter and use the original from your 4650. A replacement panel should not set you back more then $100.00 if you do not want to trash the 4600.
Please rate this post if it has helped you,
Thanks, Gary
Jul 13, 2010 | Acer Computers & Internet
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
Cant find any site for FREE Drivers
Go to this link, select Notebook, and then travelmate, and then 4320, and then your operating system
http://gd.panam.acer.com/home/
May 20, 2009 | Acer TravelMate 4320 Notebook
Acer travelmate 4650, after bios flashing, no display.thanks.
HI there
Sounds like the bios flash has failed, the only thing you can do now is try to flash again, make sure you have the right bios update for that model machine, suggest you get a USB floppy drive so you are able to re-flash the bios, if it still doesn't work then the machine is rendered useless.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer TravelMate 341T Notebook
Acer Travelmate 2400series
it need a physical check up,there is connection that cut the electric  current can't direct the other part or power supply on your notebook
Oct 19, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook Logo
154 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
