Question about JVC TH-M505 System
Getting sound from center channel only on my JVC-TH-M505
Are there fuses and which ones do i need to replace
  • matetau31 May 11, 2010
    Do you (Ssolved) think I need to replace the same board if the only channel works on my JVC-THM505 is the DVD? My sound works fine when I play dvd's but I don't get any sound for the VCR or FM radio channels.
    Sergeant:
  • 254 Answers
There are fuses in the internal board but its not the problem of the fuses .actually there is a ic  in the circuit board the number is IC349J that is calledsound audio ic .that ic needs to be replaced as its the faulty ic thats making this problem.its got internally weak on the board .so some channels not receiving proper sound.
Posted on Mar 07, 2009
  • 53 Answers
Check the jack female and male jacks r allright
the connection is correct u need to check these first
then u if nothing works use the fuse replacement
Need to replace fuse for dvd
Just pull each fuse one at a time replacing them right away until you find the bad one.
Feb 29, 2012 | 2007 Ford Expedition EL XLT
System not working when switched on.Observed 3 amp fuse blown. Replaced with 13 amp fuse and switched to manual. Sparks and noise coming from one motor. ? brushes or motor need replacing.
Fuses blow for a reason. It's never a good idea to replace a fuse with a higher amp one. House fires can easily be started this way.
As for the motor, at this point the whole motor will need replaced.
Jan 15, 2011 | Beam Industries 2900 Serenity Plus Central...
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
Need to replace a 20 amp fuse, for the auxiliary cigarette lighter, located on the right side of the console. Do not know how that is labelled, on the fuse box diagram.
Just take out your fuse box and see the fuse diagram there. If it was removed, just check one by one your fuses by visual check. You should found the blown fuse is disconnected ( melting) inside the body. None of instrument you need to use but visual check only. Then replace the blown one.
Regards, Jay
Dec 29, 2010 | 2004 Chevrolet Cavalier
My 2006 ford expedition el blew a fuse for my cig.lighter my kids plug in for psp games i have the fuse cover open but don't know which fuse # to replace. need a fuse layout.
The owners manual states 'do not plug accessories into the cig. lighter.' They are only to be plugged into the 'power point' outlets. This is probably why the fuse blew, it can't handle accessories. You need to replace fuse #41 with a 20 amp fuse. This fuse also controls the OBDII diagnostic port, so until it's replaced, you won't be able to scan for check engine codes. If you need a replacement manual, you can download one for free at the official Ford site.
Aug 09, 2009 | 2006 Ford Expedition
Can you hook the jvc th-m505 to your tv for suround sound? and if so how?
your tv needs to have audio outputs... run the rca wires from the out to the in on your system in the aux 1 or whatever you choose for your tv
Jul 30, 2009 | JVC TH-M505 System
JVC TH-M505 System Logo
271 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
