Question about Nokia N95 Smartphone
My Nokia N95 battery discharges in 6 hours.
This was purchased in Oct.2007. Even if battery is fully charged, it is discharging in 5-6 hours. Do I have to replace the battery?
  • Anonymous Apr 26, 2009
    battry drance in 6 hours
    President:
  • 1,223 Answers
Check WLAN and bluetooth first if it is switched on it will end up in short battery life Secondly
may be ur battery is faulty bcoz sometimes battery life ends in 1 year if charge cycles are enuff it also depends how ur phone OS handles the battery usage i mean how much it needs to standby and work and also the network quality i mean signal strength how hard ur phone has to strive for signals in remote areas or far from towers
pls try this first b4 buying battery
try resetting the phone like this
1) *#7370#, then enter 12345 (This is the default security code unless the user has changedit) and then Yes. The phone then wipes all apps and phonebook contactson the internal memory.
if problem persists then pls update urphone software from www.nokia.com select ur region and ur phone fromlist then download software update application backup ur data if itlets u do it and then download the phone software and update ur phonewith latest software if problem is still there then
Buy a battery !!
PLS RATE ME FIXYA for help !
Posted on Apr 03, 2009
I just purchased a Toro e-cycler cordless mower, model # 20360. I tried plugging in the charger to the Ac outlet and the mower receptacle. My understanding is that the charger light is suppossed to be...
It could be that the batterys don't need to be changed and shouldn't be unless fully discharged, if u charge before the batteries are fully discharged u run the risk of damaging the batteries. The problem is sometimes batteries get what is called a memory charge, this means if u use your lawnmower for a short time than charge it and u do this repeatedly the batteries will only discharge for this sort time and will only charge for a sort time. Than if u need it for a big job it will seem that u have only operated it for a little time and u need to plug it in. The only way to fix the batteries is buy new ones, that way they always tell u to always fully discharge before recharging your batteries.
Sep 15, 2011 | Toro Garden
My hp pavilion dv4 laptop's battery cannot sustain even for 1 hour.please give some ideas to maintain the battery and is there any remedy for this issue.Also which is better among, using laptop always...
If the battery appears to be charging, the drop in the time it sustains power is likely due to a faulty or old battery. Eventually it will appear 100% charged and drop to zero in 5 minutes or less. I would think you need to replace the battery.
If you want to maintain the battery properly, it is best to remove it once fully charged and use on ac power alone. If using the laptop on battery, remove the AC connection and allow the battery to fully discharge before recharging it ( there is some debate on this method, other may disagree)
Jul 14, 2011 | Computers & Internet
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Battery is discharged very early even without use
Hello Sunil,
Knowing your phone's behavior, Its not usual that the battery if fully charged, will drain within the day, especially that you said even if it is not being used. I would highly advice that you avail the warranty of this phone since you have just purchased that unit. Do not rely on Nokia's customer service online. Go to the store where you made the purchase and avail the warranty. They should change the battery pack.
Nov 03, 2009 | Nokia N72 Cellular Phone
I got a new nokia 6303 today..i keeps gettin switched off at will...the battery is fully charged..shud i keep on charging it for 5-6 hour even if it says that the battery is full??
Check out this link below to download a PDF manual for your phone. Just copy and paste into your browser.
http://nds1.nokia.com/phones/files/guides/Nokia_6303_classic_UG_en.pdf
From page 37 in your manual:
If a battery is being used for the first time or if the battery has not been used for a prolonged period, it may be necessary to connect the charger, then disconnect and reconnect it to begin charging the battery. If the battery is completely discharged, it may take several minutes before the charging indicator appears on the display or before any calls can be made.
If all else fails you can contact Nokia support at 1-888-665-4228.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Nokia 6303 Cell Phone
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
inamul@hudaz.com
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
Sep 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Nokia N95 Smartphone Logo
110 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
