Have been getting error code 020 with my TP-Link modem/router. (8004T) I can't seem to connect no matter what I do. I have called TS for my ISP and they maintain its a hardware issue which I am not inclined to believe since we just bought it. I have gone through the user guide and cannot find any error code list. Any help would be greatly appreciated.
  • 2 more comments
  • msrylvscmpny
    msrylvscmpny Apr 09, 2013
    it's a 8840T modem/router combo and I am running xp. I have tried uninstalling and reinstalling to no avail. I shut down all firewalls and even scanned the entire computer for malware/spyware. Still nothing. I am at a loss. ATM OEM (incl. ATM OEM F4) ping is failing according to diagnostics, if that helps. Called the ISP and am currently waiting on a callback for a tech to come out. Wanted to fix the problem before it came to that.
  • Brian Sullivan
    Brian Sullivan Apr 10, 2013
    what did the error code say in the event viewer ?
  • Brian Sullivan
    WAN is an abbreviation for the "wide area network" that is the same as the Internet. Each computer connected to the Internet has is a unique numeric IP address (WAN address) written in the dot-decimal form (e.g. 195.15.32.1). However, IP addressing within a local area network (LAN) is more complicated. LAN consists of a few computers within a limited area connected to the Internet via a router. The router assigns internal IP addresses to LAN computers that are different from their respective WAN addresses. Log on to a user account in Windows Vista/XP.Click "Start" in the left lower corner of the screen. if you use Windows XP, click "Run." Skip this step if you use Windows Vista. Type "cmd" and press "Enter" to open a command prompt window. Type "ipconfig" and press "Enter." In the program output find the line starting with "IPv4 Address" and read the WAN IP address. For example, "IPv4 Address .....194.56.23.17" If You're Connected to the Internet via a Router Login to a user account in Windows Vista/XP. Open a web browser and navigate to the "My IP address" website using the link in Resources. Read the WAN IP address in the top of the page. For example: "Your IP Address Is: 194.22.85.153."http://www.whatismyip.com/
  • Brian Sullivan
    http://www.tp-linkhome.com/tag/wan-port-...
  • Computers & ... Master
  • 27,725 Answers
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Posted on Apr 09, 2013
  • msrylvscmpny
    msrylvscmpny Apr 10, 2013
    I have checked the device manager and the modem is there without an x on it. I have been able to ping the modem so that tells me that it is configured properly. The issue is when I run the resource CD for the modem, I get an error 020. It tells me to check the Wan parameters but I am unsure of how.
  • 8 Answers
SOURCE: TP-LINK WR642G Problems with wireless connection.
Is your wlan & internet light lit?
Posted on Sep 09, 2008
anandg27
  • 1272 Answers
SOURCE: PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Posted on Sep 06, 2009
  • 477 Answers
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Posted on Mar 08, 2012
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
  • 3 Answers
SOURCE: ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Posted on Dec 06, 2008
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
L cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
Bsnl adsl modem configure with TL-MR3420 router!
TP-Link Router not working, want to setup TP-Link router, have troubleshooting issues. No need to worry we are here to provide you the best solution according to your requirements of router issue. You just need to dial TP-Link Router Helpline Number avail at toll-free number 1-833-284-3444. Our tech support team includes executives who are professional and know each & every solution which may arise at the time of accessing.
The wireless network is unstable via my wireless router/modem router
Some time router is not still connected and working that time users do follow given instruction and make the trouble-free router.
Locate wireless clients in a reasonable distance.
Get away from obstacles.
Reduce the number of wireless clients.
Decline interference from other wireless equipment.
Optimize the router's position.
Change some settings on the router.
Test the WIFI device.
Get technical service for your problem which is not understanding how to solve the technical issue, our technical expertise is available for 24*7 and they are ready for pick up the call when called by the customer. If wants to more technical service visit our TP-Link Router Service websites.
https://servicenumber.org/tp-link-router-customer-service.html
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Tenda router input eror
It's not the username and password from your ISP. If you try to access your router and you have not changed anything, use the following values:
username = admin
password = admin
Once in the router interface, you will have to configure the router for your DSL-modem (I guess it's DSL since Windstream does not produce cable modems.)
Here fill in the username and password your ISP provided you with.
Let me know if you have any questions.
Nov 14, 2012 | TP-LINK Tenda W311R WirelessN Router AP...
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
http://www.tp-link.com/resources/software/200943083466.pdf
Please mark as solution if this helped you at all.
Thanks.
Jan 29, 2012 | TP-LINK Computers & Internet
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
TP LINK MODEN ROUTER ADSL2 PROBLEM
If the PPP LED is flashing all the time then you have not got a connection to your ISP's server.
Have you contacted your ISP?
The ISP can test the ADSL connection to the your ADSL2 modem and advise whether it is a fault or not..
Sep 17, 2009 | Computers & Internet
Computers & Internet Logo
4,615 people viewed this question
Alun Cox
David Payne
David Payne
