Question about Janome Memory Craft 3000
I can't find where to insert the extra spindle for the upright thread spools it is not in my manual.
Hi, look to the right of the spindle holder that lays across the machine, you'll find a little square hole and that is the spot.
Posted on Jul 17, 2009
How come spindle is so short to put spool thread on
Is it the spindle for the top thread or is it the spindle to wind the bobbin? The bobbin is very short because it needs to accommodate only the width of the bobbin. Older machines sometimes do not have thread spindles tall enough for the large spools of thread that can be purchased today. I cut a plastic drinking straw into a length long enough to accommodate the thread spool and simply slip the plastic straw over the thread spindle. Voila! A longer spindle!
Sep 04, 2017 | Sewing Machines
How do I replace the spindle to hold the thread on my machine it has snapped off
sadly we can not say as we do not know the make of your machine . suggest you try the manufacturer's website for customer support .
Jun 18, 2016 | Sewing Machines
What is the best thread to use on the pixie plus machine. A lot of the threads do not fit.
I am not sure why they would not fit but embroidery thread is thinner than general purpose thread so it might work. Good luck.
Mar 25, 2015 | Singer Pixie Plus Sewing Machine
Why does my thread get wound up on the spindle of the pfaff 230 sewing machine
Do you mean the spindle that holds the spool of thread, on the machine's top ?
If it's winding on that, chances are it's something about the spindle itself. Check that there isn't a loose washer under the spindle. If there is, check the washer for any rough spots, it may need replacing. Make sure the spindle is firmly screwed into the machine, if it screws in. If it's welded on, make sure there are no rough spots. If all that's ok. try putting a felt washer under the spool. You can b buy them but they're easy to make. Just cut a spool base size circle out of firm felt, and snip a hole in the middle just large enough to slip onto the spool. A leather punch works great for this. If it's still winding up, check the instructions, if you have them, and make sure you have the thread coming out from the spool in the right direction.Some machines are very picky about how they are threaded. For some, the thread must come from the back of the spool, for others, from the front of the spool. Try both to see if one orientation works better. And last check there is no rough spot, either on the needle or any of the thread guides. If the thread is being chafed anywhere along the thread path, excess tension may result, which can cause the thread to start winding on the spindle. Changing the needle is easy. Changing a guide may not be, but if it's a guide that's got a rough spot, see if you can remove the guide and then smooth the rough spot using some very fine sandpaper or emery cloth. The entire thread path has to be perfectly smooth for thread to move as it should.
Oct 09, 2014 | PfaFF Sewing Machines
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
I have a brother 6000i. How do I utilize the extra spool pin?? Where does it go ?
bAttach the extra spool pin.
Put the extra spool pin in the hole on the top of
the machine. Put the second spool of thread
onto the extra spool pin.
See page 25 in owners manual.
Feb 25, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Thread breakage and bobbin tangles
These might be caused by one issue, or by separate issues, so you need to test to identify it, but that doesn't take long.
You need to take out your user's manual and make sure that you are threading it correctly. You might also want to take your spool out of the spindle on the machine. Put the spindle that came with it for twin needle sewing on the top, and put the thread at the back of the machine in a coffee cup, then bend it around the base of the spindle, and then thread normally--exerting tension at the top and bottom when you do so, and making sure that your presser foot is UP--ALWAYS up on ANY sewing machine. That is the only time that the tension disks are spread to admit the thread, and a possible cause of your problems.
Next, review how you insert the bobbin, and make sure that the bobbin case was properly inserted, and the thread is properly threaded, with the bobbin going in the correct direction.
Also, you might want to switch to either a slightly larger needle, or a metallic needle, which is a regular needle in a range of sizes, but has a larger eye. Also, try another spool of thread to make sure the problem is NOT the thread, which might be old--even if you just bought it, it may have been sitting on a shelf.
Feb 15, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
My bobbins sometimes don't wind right. The thread gets all tangled at the bottom of the bobbin instead of winding evenly. I'm sure it's user error because sometimes it works. Hoping you can help me figure...
when the thread is on the spool pin
1.guide the thread around the bobbin winder thread guide
2.insert the thread through the hole on the bobbin, threading from the inside to the outside
put the the bobbin spindle
3.push the bobbin winder spindle to the right (if you have a electronic machine the LED display
will show SP)
4.depress the foot control, when the bobbin is fully wound, stop it, & push the bobbin spindle to the left, cut the thread & remove it from the spindle
Nov 17, 2010 | Simplicity Sewing Machines
THREAD CARTRIDGE WONT LOCK IN PLACE
Hi - I'm sorry you have been waiting for an answer to your problem. Can you tell me whether this was first time you used the cartrige, or has it been working up until now? Unfortunately, the cartridges tend to break fairly easily.
To determine whether your cartridge is broken, take out the thread and thread it again. The cartridge won't lock-in unless your presser foot is up and your needle is raised to its hightest position (needle threaders are designed to prevent damage, so they often won't work if the parts of your machine are not positioned properly for threading).
If the cartidge still won't engage, check the page in your manual that describes the parts that came with your machine - you should see a picture of a spool pin. Although the spool pin is designed to accommodate spools of thread that don't fit in your cartrige, you can use the spool pin all the time. Your manual describes how to install the spool pin.
Fortunately, you can purchase spool pins and replacement cartridges from several online sources, including eBay, and some Babylock Dealers sell them (the Babylock and Brother cartidges are interchangeable). I have the same machine, and I always keep an extra cartridge around. I can thread the extra spool while the other is sewing. When the machine stops for a color change, I just insert the extra cartridge with the next color, then thread up the empty cartridge for the next color. Speeds up your embroidery alot.
On Google, type in Brother Thread Cassette - you'll get lots of hits, and you should be able to find a cartridge for about $10.00.
If you have and other readers have time to rate my answer (good or bad), your rating helps me determine whether I understand your problem.
If you have more details about your problem or have additional questions, please feel free to comment. I can send you the instructions for threading the cartridge and installing the spool pin if your manual is missing. Just submit a comment - and I'll help anyway I can.
Cheers, Ginny
Jan 18, 2009 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
