Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Trying to install new Honeywell TH8110 thermostat
We have an old thermostat with wiring letters O, W2, E, G, R, Y,and L. So we are trying to figure out which wires corresponds with the new thermostat.
We have a heat pump.
  • Todd Born
    Todd Born May 11, 2010
    THAT WAS APPARENT WHEN YOU SAID O, W2 AND E. WHAT TYPE OF STAT DID YOU GET?
  • 700 Answers
ALL OF TEM
EXCEPT L
Posted on Mar 07, 2009
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Installing a honeywell thermostat with a goodman cpke24-1ab heat pump
r is red c is blue w is white y is yellow g is green o is orange w2 is w2 is also white e is brown but some installers dont follow that pattern so maybe this helps red is 24voltpositive c is 24voltnegative yellow is compressor white or w2 is heat brown is emergency heat orange is reversing valve green is fan
Mar 31, 2013 | Goodman CKL30AR30 Air Conditioner
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
I am trying to replace my old thermostat with a programmable one, but the wiring diagram on the new one does not incorporate all of the wires that are currently attached. Please help.
The existing connections are O, R, Y, G, C, E, W2. Yes you will need a thermostat designed for the electric heater coils as indicated by the E terminal. The W2 could indicate a second stage cooling compressor.
Mar 05, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
Where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Jan 25, 2010 | Honeywell Programmable Thermostat Heater
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
242 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
