Question about AT&T Blackberry Curve 8300 Smartphone
My phone wont let me use the camera
On the blackberry curve when i try to open the camera it says "could not start the camera. CLose other application and try opening canera again?
    Brigadier General:
  • 7,752 Answers
You need to have the OS reflash on the phone....you can following these steps
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows,
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. My phone wont let me use the camera - biggrin.gif
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
Posted on Feb 04, 2010
Blackberry camera problem
Any other program using the camera? (such as custom filters.. etc) if you have anything that is using the camera application then it won't actually close until you close the hosting program; easiest way is to take out the battery WHILE THE PHONE IS ON (important part, that's why I yelled it :) ) and leaving it out for about 10-20 seconds, reinsert and try again
Apr 18, 2013 | RIM BlackBerry Curve 8520 Smartphone
When i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
when i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
Oct 10, 2010 | RIM BlackBerry Curve 8520 Smartphone
Camera ERROR MESSAGE Blackberry Curve (Sprint)
Your OS maybe corrupted so you will need to reinstall the OS, you can do this by connecting the phone to your pc/laptop using the USb cable then open the Blackberry Desktop Manager and click on the apploader then install the applications and install the OS as well as the features for the phone....
Thks
Bajan Guru
Barbados4life
Dec 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the Blackberry.com website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Could not start the camera. Close other applications and try opening the camera again
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
AT&T Blackberry Curve 8300 Smartphone Logo
107 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
